Power rear slider
Old Aug 28, 2009 | 08:15 AM
rpenterics's Avatar
rpenterics
Power rear slider
I'm gettin ready to put a power slider in my '02. Can anybody tell me what wires go where? I have 6 coming of the switch and 4 off the motor. Also does any one have a picture of where the motor is attached on the rear of the cab?
Old Aug 28, 2009 | 08:19 AM
69cj's Avatar
69cj
Your in the wrong forum for an 02.
Old Aug 28, 2009 | 08:24 AM
rpenterics's Avatar
rpenterics
I assumed more people in this forum would have the power slider option, and the window is the same.
Old Aug 28, 2009 | 09:34 AM
jeff7825's Avatar
jeff7825
Connect the matching colors for the motor to the switch. Then I would say one of the wires you have left at the switch is an illumination wire. The other not sure, maybe a ground. I hope you get this figured out because I would like to install one of these in my truck as well.
Old Aug 28, 2009 | 10:35 AM
04redstroker's Avatar
04redstroker
I dont think the switch is illuminated, at least i dont think mine is.lol If I get time ill try and pull the cover off and take a few pics.
Old Aug 28, 2009 | 11:06 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Hmmm... that would be nice to have. What did it cost you, and what parts are involved?
Old Aug 28, 2009 | 12:41 PM
natem8301's Avatar
natem8301
I think it's all one assembly including glass.....I think it was $850 when I priced it out decided I didnt need one that bad hehe
Old Aug 28, 2009 | 01:14 PM
rpenterics's Avatar
rpenterics
I scored the full window assembly and switch for just under $200, putting it in is gonna cost another $95. My problem is that it was out of a wreck so the wiring was cut. I also don't know where the motor is supposed to mount on the back wall
Old Aug 28, 2009 | 04:08 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Yeah, me either. I think I'd spend the money on a heat extractor hood first. Or maybe an EGR delete, or maybe ARP's, or maybe more gauges, or maybe... You get the point.
Old Aug 28, 2009 | 05:38 PM
rob40cal's Avatar
rob40cal
From 2006 f350 Motor mounts on passenger side just off the moving glass, just below the window
Pin1 VT/LB rear window adjust sw. to motor
Pin2 LB/BK Accessory delay relay
Pin3 BK Ground
Pin4 BK Ground
Pin5 LB/RD Instrument Ilumination feed
Pin6 BK Ground
Pin7 VT/LG rearwindow adj. sw. to motor
Old Aug 28, 2009 | 09:56 PM
jeff7825's Avatar
jeff7825
Pin3 BK Ground
Pin4 BK Ground
Pin6 BK Ground
This is the pinout for the switch I assume.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Aug 29, 2009 | 01:00 AM
rpenterics's Avatar
rpenterics
That's exactly what I was looking for Rob. I'm getting the windows swapped in the morning, and should have it runnin in no time. Thanks, reps to you
Old Aug 29, 2009 | 01:18 PM
jeff7825's Avatar
jeff7825
If you get a chance, take some pictures of your install.
Old Sep 4, 2009 | 09:54 AM
rpenterics's Avatar
rpenterics
I was in a hurry so I didn't get any pictures with the trim pieces off but the window is in and functioning well, I love being able to use the slider finally.
The cable fit easily behind the trim on both sides
The motor is secured with three 1/4 self tapping bolts
I used the power and illumination from the adjustable pedals harness that was already behind the dash. The 2 power wires to the motor are run along the driver's side under the sill.
Rob's pinout was spot on, thanks again
Total cost $275, Total time ~1.5 hrs
Old Sep 4, 2009 | 12:29 PM
jeff7825's Avatar
jeff7825
Nice. I really want to add this to my truck.
Amish Ford
Jul 24, 2016 05:24 PM
gg1968
Feb 6, 2016 10:15 PM
GRIMJEEPER
Aug 12, 2015 03:38 AM
davehaynes
22
Jul 12, 2011 06:15 AM
ed2hess
23
Jan 7, 2011 02:08 AM
