shift linkage/bushing/grommets
Old Apr 8, 2015 | 07:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Updated info:
EOSZ-7341-B (replaced C7SZ-7341-D ~ C8OZ-7341-A ~ C9TZ-7341-A ~ D4OZ-7341-A ~ D4ZZ-7341-A ~ D5AZ-7341-C ~ EOSZ-7341-A) .. Nylon Selector Lever Bushing / Available from Ford
Myriad 1967/80's FoMoCo vehicles.
Old Aug 20, 2015 | 01:58 PM
jackslater's Avatar
jackslater
I've been visiting/posting/lurking in the Ford forums for years and am amazed at you parts knowledge - Thank you!
Anyway, I recently ran across a transmission linkage bearing/bushing for a 68 Galaxie 390 that I'm missing.
My MPAC says the part number is a C7SZ-7341-B.
I'm sure it's obsolete, but does it possibly cross-reference or is there a replacement part number?
It's probably common bushing I might be able to get from Dorman?
I've always wondered, is there some reference book available (for a price, I'm sure) that would allow me to look up part numbers for replacement, cross-reference?
Thanks mucho in advance!
Old Sep 15, 2015 | 08:54 PM
ldgamblin's Avatar
ldgamblin
NumberDummy, Is BUSHING - FORD (EOTZ-7335-C) the bushings at the bolt/pivot point on a NP205? My truck is a 79 F150 4x4 4spd 351m.
Old Sep 16, 2015 | 07:25 PM
NumberDummy
My MPAC says the part number is a C7SZ-7341-B / I'm sure it's obsolete, but does it possibly cross-reference or is there a replacement part number?
EOSZ-7C327-B replaced C7SZ-7341-B .. D5AZ-7C327-A .. EOSZ-7C327-A / Obsolete
Source: 1991 O-S-I (Obsolete-Supercede-Interchange) catalog on microfiche.
EOSZ-7C327-B ~ Sources with the largest quantity =
LINCOLN LAND in Clearwater FL has 14 = 727-446-2193.
PARTS INTERNATIONAL sold out to Bob Allen Ford
GREEN SALES CO. in Cincinnati OH has 29 = 800-543-4959.
Last edited by NumberDummy; Dec 10, 2018 at 11:11 PM. Reason: edited 12/10/2018 with Bob Allen info.
Old Dec 10, 2018 | 01:09 PM
Cougar2's Avatar
Cougar2
I have a 1979 F350 4x4 and there is a bushing in the shifter linkage I can't identify. I know Bronco Graveyard has shifter bushings, but I don't think it applies to this one. I have included a picture of the (not exact) linkage, "reference only", but it is the one near the the outer bracket 7C324 in the picture. This truck has a C6 automatic, Is this called a bell crank bushing?
After reading this page, I see that there are color codes as well. There isn't much left but a small piece sticking out of the pivot point. I will see If I can get a color off of that.
Old Dec 10, 2018 | 02:28 PM
NumberDummy
I have included a picture of the (not exact) linkage, "reference only", but it is the one near the the outer bracket 7C324 (invalid part number) in the picture. This truck has a C6 automatic, Is this called a bell crank bushing?
Parts Catalog pic below:
Pic shows the 1973/77 NSS location and 1979 F350 4WD isn't listed, but it's the only pic there is.
Only bushing is 7341 (EOSZ-7341-B) that I listed twice in this thread. There's two locations, so 2 bushings.
Old Dec 10, 2018 | 03:01 PM
Cougar2's Avatar
Cougar2
[QUOTE=NumberDummy;18353024]Parts Catalog pic below:
Thanks for your response. I will take this picture to the dealer and see if they can get the part. The 7A185 looks more to be the one I need. It figures that the one I need is hidden in the picture. It's the one closest to the frame near the bracket, bottom shaft. This is a good start. I know there were numbers given before in this thread, but with the hand full of bushings, locations of those were puzzling. I will take this one , "what's left of it" out to see if there is any color left to it as well.
thanks!
Old Dec 10, 2018 | 08:52 PM
NumberDummy
[QUOTE=Cougar2;18353075]
thanks!
EOSZ-7341-B .. Nylon Bushing ~ Available from Ford, see post #16 for most of the part numbers it replaced.
MSRP each: $4.48 // autonationfordwhitebearlake.com online discount price each: $2.96 .. Prices will vary from one dealer to another, especially in Canada.
White Bear Lake is located in MN
Old Dec 10, 2018 | 10:02 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
In that pic, item 7c431 as well as 7a185 house bushings that support the bell crank; were these bushings available or was this a total component replacement? Thanks numbers.
Old Dec 10, 2018 | 10:57 PM
NumberDummy
The only bushings shown in the pic I posted are basic part number 7341.
Both the bushing shown in the 7302 selector lever on the column and the 7A256 manual control selector lever on the trans are the same: EOSZ-7341-B
Old Dec 10, 2018 | 11:01 PM
DB429SCJ's Avatar
DB429SCJ
PARTS INTERNATIONAL in Farmers Branch TX has 18 = 888-727-0418.
C7SZ-7341-B (r/b E0SZ-7C327-B, thanks ND) is listed as : bearing - transmission column shift selector bellcrank. 7/16 i.d. 11/16 o.d. 13/32L
Old Dec 10, 2018 | 11:05 PM
NumberDummy
Wonderful, but the applications for this puppy is 1973/76 F100 360/C6 4WD
This thread was dead without a post in 3 years (9/15/2015) before Cougar2 dug it up yesterday.
He has a 1979 F350 4WD, so there's no 7C327 bushing listed.
Old Dec 11, 2018 | 06:36 AM
  #28
Cougar2's Avatar
Cougar2
I went to the Ford dealer last night and I gave them the numbers, 7A185 and EIFZ-7F330-A. He said the 7A185 was a bracket # without looking at a book, but the EIFZ-7F330-A was the bushing, a package of two. I ordered them and they will be here this morning. I used the photo that NumberDummy posted and he was able to say this was the part needed. Thank you NumberDummy!!
Old Dec 11, 2018 | 10:45 AM
  #29
F-250 WARHORSE
So in that bell crank bracket the part 7c324 has a bushing in it, a brown or orange rubber one. it is larger than the bushings in the lever on the bell crank. Were these available or was this a whole bracket replacement? thanks for the pics guys.
Old Dec 11, 2018 | 12:28 PM
  #30
NumberDummy
So in that bell crank bracket the part 7C324 has a bushing in it, a brown or orange rubber one. it is larger than the bushings in the lever on the bell crank. Were these available or was this a whole bracket replacement? thanks for the pics guys.
Geez Louise! You can lead a mule to water, but you cannot make it drink!
Where did Cougar2 get that pic? It's WRONG! There is no .. repeat no 7C324 listed for Cougar2's truck, none!
And, E1FZ-7F330-A is the WRONG bushing. This is for a 1981/89 Escort/Lynx.
I listed the correct part number several times. Why Cougar2 gave the dealer the wrong part number, I dunno.
