Hi guys, After searching through 8 pages and finding little, ive decided to post. Im putting my 390 motor back together and need torque and bolt sequences for the timing chain cover, oil pan, and intake manifold. Does anyone have a link to diagrams and specs for these?
I found these specs listed below from the web years ago. I don’t know if they are completely accurate as I used the recommendations from Steve Christ’s book (I don’t have it in front of me to compare). I am sure someone will correct the specs listed below if they look off.
<O
Lance
Main cap bolts 95-105 ft.-lbs Connecting rod bolts 40-45 ft.-lbs Cylinder head bolts (follow factory torque sequence) 140 ft.-lbs. Rocker arm shaft bolts 40-45 ft.-lbs. Intake manifold bolts ` 40-45 ft.-lbs. Oil pump bolt 12-15 ft.-lbs. Cam bolts 40-45 ft.-lbs. Harmonic damper bolt 70-90 ft.-lbs. Flywheel/ flexplate bolts 75-85 ft.-lbs. Pressure plate bolts 35 ft.-lbs. Front cover bolts 12-15 ft.-lbs.
