auto meter pyrometer
Old Aug 24, 2009 | 12:22 PM
mudbug04's Avatar
mudbug04
hey guys, hopefully just a quick question but me and a friend installed my auto meter z-series 3 gauge pillar pod this weekend but didnt get to finish the install of the pyrometer due to lack of a tap. Well i have a tap now and he is busy and i was wondering if i need to worry about shavings falling into the up pipe since i will be doing it myself probly. If i should be concerned about shavings what is the best preventative step to take besides the lube, i was told by many to keep it dry.. thanks for any input.
Old Aug 24, 2009 | 12:46 PM
clintbonnie's Avatar
clintbonnie
Your should drill and tap the exhaust manifold at it's lowest point where is bends. Use grease on the drill and tap..( I used my big shop vac and suck out any shavings that might have got inside).. Make a test hole in some scrap metal and tap it first.. If you go too deep with the tap, you are in trouble.. your sensor will not seat tightly in the threads..
Old Aug 24, 2009 | 01:01 PM
mudbug04's Avatar
mudbug04
ok so if some metal IS left behind in there will it hurt anything? or will it just blow out?
Old Aug 24, 2009 | 01:08 PM
clintbonnie
You are drilling and tapping in a up direction, so if any small amount of debris is left in the hole, using a vac should remove them.. Cast iron has small chips and should stick to the grease..I would not worry too much.. Another tip is to drill in steps.. smaller drill 1st.. and remember not to tap too deep..
Old Aug 24, 2009 | 02:22 PM
Pocket's Avatar
Pocket
Anything left behind will be blown out. At idle, the turbo isn't spinning fast enough for any tiny metal pieces to even affect the wheel. Countless people have drilled/tapped/installed the probe, and none have destroyed a turbine wheel.
If you want to vacuum out the shavings, there's no problem doing that. I never did, and I've installed 2 probes on my truck since I've owned it. One went in the up-pipes. Then when the up-pipes got replaced, the new one went in the manifold. Neither installation caused any problems.
Old Aug 24, 2009 | 02:40 PM
mudbug04's Avatar
mudbug04
you actually drill and tap it so the probe is comming out from the bottom?? i was under the impression it goes out to the side...
Old Aug 24, 2009 | 02:58 PM
clintbonnie
Look at the following FTE thread ... scroll down and there is a pic of the manifold.. I guess it isn't exactly straight up but pretty close to it... see:
https://www.ford-trucks.com/forums/8...-location.html
Old Aug 24, 2009 | 03:23 PM
mudbug04's Avatar
mudbug04
looks good to me, hopefully i'll be finishing it in the next week, thanks for the help guys
PAVEMENTMAN
24
Sep 30, 2008 04:49 PM
97powersmoke
65
Sep 12, 2008 05:46 PM
PAVEMENTMAN
13
Aug 6, 2008 02:20 PM
96powerstroke
Dec 1, 2006 07:33 PM
rdahl
Sep 10, 2003 04:07 PM
