Sponsored by: Auxito
Outside Air Temp Calibration?
Old Aug 23, 2009 | 02:28 AM
mcdev's Avatar
mcdev
My outside air temp sensor went bad a few months ago. It was showing 140F all the time. Finally got around to changing it out yesterday and it is now showing about 102 degrees. That would be fine but it is about 55 degrees here. Is there a way to calibrate this thing or is it another bad sensor?
Old Aug 23, 2009 | 07:45 PM
IndySilverAnny's Avatar
IndySilverAnny
Mine's reading 35F... It's been in the 90's until this weekend, and now it's in the 70's. I checked Autozone and they don't have the temp sensor. Where'd you get one?
Old Aug 23, 2009 | 07:59 PM
mcdev's Avatar
mcdev
I ordered mine from O'Reilly Auto Parts. Came pretty quick too. It was about $30 including tax and shipping. Now if I could only get it to read the right temp... Anyone out there have any ideas?
Old Aug 23, 2009 | 10:08 PM
torkum's Avatar
torkum
Might want to try the self test on the system. Read the second post for instructions on how to perform the test:
https://www.ford-trucks.com/forums/2...self-test.html
Sounds like you could have a ground problem in the wiring from the sensor to the control unit.
Old Aug 24, 2009 | 12:08 AM
mcdev's Avatar
mcdev
Torkum, thanks for the help. Unfortunately I have a 2000 F150 and all my HVAC controls are manual and not electronic. The ground fault idea is a good one though and I will look into that.
Old Aug 25, 2009 | 08:47 PM
IndySilverAnny
Besides, he is looking at calibrating the thermometer, not the electronic VAC controls.
Is there a way?
Old Aug 25, 2009 | 09:08 PM
torkum's Avatar
torkum
If the thermometer is between 8,000 and 14,000 ohms it's ok. There is no calibrating of the sensor.
Old Sep 6, 2009 | 05:09 PM
IndySilverAnny
I also replaced my sensor but it made no difference. It still reads way low. Today it was reading 30deg. when it was close to 80. Any other problems this could be?
BTW, Mine was $47.50 from O'Reilly...
fdnylax
Sep 22, 2017 12:58 PM
hpcbmw
Jan 29, 2017 02:18 AM
microbc
Nov 11, 2015 11:27 AM
microbc
Jun 20, 2015 01:45 PM
Lucky.Cookie
Jul 25, 2009 08:12 PM
