ECU Calibration?
Old Jul 25, 2009 | 07:06 PM
Lucky.Cookie's Avatar
Lucky.Cookie
Question ECU Calibration?
1996 XL F150 4.9L I6 170K miles, dual tanks, manual tranny, 2wd.
I'm currently looking to replace my truck's ECU. The numbers I can read on my ECU sticker, without pulling it out (need truck), are F6TF-EC HIX2.
Placed call to local dealership - part discontinued and gave a part number of F6TF 12A650 AJA.
Placed call to local parts store. Number given by Ford not helpful and they show 5 ECU's depending on calibration.
Found part on Ebay of F6TF 12A650 EC....indicates it was pulled from 1996 F150 but no engine size noted. Why would beginning four numbers of part number be different from Ford and the one that's original in my truck? How do I find out what my correct calibration is?
Hoping that replacing ECU will take care of a few problems. Last 5 years check engine light has been on with constant P171 and P174 codes, lean bank 2. Replaced: All three O2 sensors, mass air flow sensor, fuel filter (a few times), spark plugs/wires, EGR valve, and coolant temp sensor. Don't know what else to do. Temp gauge also is not working and have recently tested it - guage itself is fine. Truck doesn't want to start when hot, but once cooled, fires right up. Within the last week the battery light has been occassionally coming on and going off..... *Frustration*
Any help on which ECU/computer is correct would be helpful.
THANK YOU!
Old Jul 25, 2009 | 08:12 PM
frankyford's Avatar
frankyford
Try O'riellys auto parts that's where I got mine. I'm having the same issues with my 95 F-150 302 auto. Just got done taking the new MAF sensor back and got my old one back. Seems the new one changed nothing on my truck and I've replaced everything including the computer and I'm taking it back to O'riellys tomorrow. That said I don't think it's your computer(PCM as we call it) and I'm still trying to figure it out. Hopefully I can save you some money.
darthice
17
Feb 5, 2024 10:36 AM
Chris96f250
Mar 17, 2016 08:59 PM
z21Gameplay
Escape & Escape Hybrid
Jan 22, 2016 06:43 AM
PathAss
Mar 10, 2012 10:31 PM
84Fordvan
22
Jan 22, 2011 10:33 AM
