Has anybody used one of these http://www.bernzomatic.com/PRODUCTS/...3/Default.aspx
to heat up rusted nuts and bolts cherry to loosen them? The new shop I work in has no torch and this would be nice to have in my box for those occasions.
ya know you might check with the fire marshal- if the business is classified as a B or S occupancy, torches are prohibited (only in H are they aloowed or H designed/built areas within a B or S).
There are also electric units that are specific to applications you are speaking of, a small clamp attaches to the nut/bolt, you turn it on and in just ab couple of minutes it's red hot- probably much faster/safer than a cgas torch.
yeah I was told something about not being allowed to have a torch there yet there are a couple propane torches laying around.
I am aware of a tool called a mini ductor that is electric like you said which I would love to have but at $500, not right now.
really without oxygen it will heat a bolt fast? In your guestimation how long for a nut with a 3/4" head?
Not sure, I never really timed it. I wasn't sick of holding it there by the time it was hot though- Under a minute for sure.
I think that these aren't regulated under fire codes, since anything you can do with a handheld single bottle torch really doesn't qualify as hot work within the fire code.
The hose torch can be fed from a 20lb typical barbeque propane tank via the common adapter hose sold in hardware and chain stores. I haven't bought a small propane bottle for many years.
