Sponsored by: Real Truck
Ebay leveling kits
Old Dec 19, 2013 | 01:07 PM
Torched03Mach's Avatar
Torched03Mach
Ebay leveling kits
Normally I'm not one to go for cheap pieces but I kind of got to thinking...It's the same thing as the rest of the kits, just an aluminum puck and a couple bolts, could this really be that bad? For $10, I couldn't buy the aluminum to make my own...
2005 2011 4WD Ford F250 F350 2" Leveling Lift Kit | eBay
Old Dec 19, 2013 | 01:20 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
For $10 I'd at least buy a newset of bolts just to be sure, if you shear off the lower spring perch you're going to have a bad time. My biggest concern would be if they're cut correctly, they need to have a beveled edge to match up with how the C of the axle comes off the spring perch. I ran this type of spacer for awhile, I pulled it and decided I'd use coils springs before I went this way again. It's cheap, but not ideal.
Here's the bevel:
Mine were like this next picture picture, they were cut with a beveled edge, and with two points to match up with the spring perch that you're putting the spacer under. The brake line bracket mounts to the spring perch, so if it was allowed to rotate that could cause problems.
Maybe this shows it better:
Old Dec 19, 2013 | 02:38 PM
Jacob Rivers's Avatar
Jacob Rivers
I'm going to be installing a 3.5" lift kit from Freedom Suspension on ebay this weekend, I will let you know what kind of quality it is once I'm done.
Old Dec 19, 2013 | 08:41 PM
Torched03Mach
Here's the bevel:
Thanks guys, this whole truck thing is new to me, normally I'm working on race cars/hot rods of some sort. At least with some of those, the cheap pieces are the same thing as the name brands in a lot of cases, so I didn't know if anyone had went this route!
Old Dec 20, 2013 | 09:35 AM
Jacob Rivers
No problem, I've owned 4 different trucks with ebay leveling kits. All held up and were as good quality as the more expensive name brand crap. The one I'm installing this weekend looks like quality parts, no cheap junk. I've done several leveling spacers for friend off of ebay also, you know the $59.00 specials, all have worked great.
Old Dec 20, 2013 | 10:56 AM
droldsmorland's Avatar
droldsmorland
The only advice I can give is general and its safety driven. 100% of my experience with offshore "parts" is that the chinesium WILL have inferior fasteners. While the solid pieces may not be the highest quality they may survive quite nicely in an HD chassis (??) but the bolts wont. Ive learned my lesson with this crap. If at all possible I will buy USA no matter what it costs and Im not rich. IMO piece of mind usually guides me to the USA made hardware (and all other parts if offered the choice) for MANY reasons...mainly safety.
Old Dec 20, 2013 | 04:48 PM
Torched03Mach
Haha I appreciate it man!
I don't buy Chinese junk either, I've always been all for American made products!!! I just didn't know if the actual aluminum spacers were worth a damn lol.
Old Dec 23, 2013 | 08:29 AM
Jacob Rivers
Ok, so I intalled my 3.5" lift kit on my 2013 F-250 this weekend. The kit was purchased through Ebay from Freedom.suspension. The kit was decent quality with the exception of the directions, they really sucked. Luckily I've installed several lift kits before. If you've worked on race cars this should be no problem for you. Hope this info helps, Good Luck!!
Old Jan 30, 2014 | 02:55 PM
mrwrench's Avatar
mrwrench
I have 2" lower spacers and my truck and it drive very roughf , it jump in every bump on the road. Also the steering shake when it turn with in 4x4.
Question: will the top rubber spacers make any difference of the driving conditions?
thsnks
Old Jan 30, 2014 | 03:09 PM
Jacob Rivers
Talking
thsnks
Are you serious??? You lowered a 4x4???
What kind of truck?
Top rubber spacer reduces squeaking and prevents vibrations from transfering through supension.
Steering shakes when turning in 4x4 because you are on pavement. Try 4x4 in mud....
Old Jan 30, 2014 | 03:42 PM
txjfrosty's Avatar
txjfrosty
Wow, that looks great! what size tires? I just looked up Freedom Suspension on ebay... they have a bunch of 3.5" lifts available... would you happen to know which one you bought? I comparing lift now... Zone, BDS, and others. I want to install a 3.5" - 4" lift this spring.
Old Jan 30, 2014 | 03:55 PM
Jacob Rivers
36-13.00-20 or whatever that is in metric. I bought the one with the radius arm relocation brackets. I've got around 3-5K with it on now, it seems to be working fine. I run 90-100MPH on the interstate all the time with no shakes or vibrations.
But like I said before, their directions suck!!
Old Jan 30, 2014 | 04:20 PM
txjfrosty's Avatar
txjfrosty
aight cool man... thank you.
I've done a few lifts, and my buddy owns an off road shop, so I may just have him do it for me.
Old Jan 30, 2014 | 08:19 PM
mrwrench's Avatar
mrwrench
[QUOTE=Jacob Rivers;14013746]Are you serious??? You lowered a 4x4???
What kind of truck?
Steering shakes when turning in 4x4 because you are on pavement. Try 4x4 in mud.... [
2005 F250 6.0 single cab 4x4 - I raised it 2" , after that it drive very bad specially when the truck hit a bump , it is like jumping .
Old Jan 30, 2014 | 10:16 PM
redford's Avatar
redford
FTE Leadership Emeritus
Are you serious??? You lowered a 4x4??? ...
I think he meant he has the spacers that fit on the lower end of the coil springs.
