Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Cutting torches
Old Apr 9, 2008 | 08:36 PM
LiftTech's Avatar
LiftTech
Cutting torches
Hey all. I'm looking to buy a cutting torch. I've used them for years at work, but never had a shop at my house to work with one- until now.
I found a Victor torch set tonight at Tractor Supply. It includes hoses, regulators, the torch head, a couple of tips, a cart, and tanks. They aren't full size tanks, but they're larger than the 'portable tanks. I'd guess they might be 50 pound tanks?
Has anyone seen this set? Is $649.00 a decent deal? Is there anything else I need to know before buying a torch set?
Thanks!
Old Apr 9, 2008 | 10:39 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
That seems kind of high priced. I would go to your local welding supplier and ask what kind of deals they have on torch sets. I'm betting they can beat that price and get you some better equipment.
Ask if they have Harris torches and compare them to the Victor. The Victor Journeyman is a very good torch, but for the medium sized torches you are looking at, the Harris is a better torch at a better value. Victor is pricey. I checked into getting a new cutting attachment for our Journeyman at work and ended up deciding to buy a Harris Pipeliner torch with regulators for the same price!
I am very impressed with the Harris. We set it up for propane. You could do that too and only have to buy an oxygen tank. Just use a 5 gal size propane bottle like for a barbeque. Be warned that propane uses up more oxygen for the combustion than acetylene does. You will go through more oxygen, but it's less expensive than propane. It is very conservative on the propane usage.
Old Apr 9, 2008 | 10:45 PM
Mr Jimi's Avatar
Mr Jimi
Smile
I bought my set at ww.Grainger about 35 years ago and they work great, If you do much cutting you will go thru oxygen in a heartbeat, get a spare cylinder
Old Apr 10, 2008 | 10:51 AM
GLR's Avatar
GLR
You can probably get a better deal at a local welding supply co as horsepuller says. Get hose ( "T" ??)and cutting tip suitable for propane. I've used propane for years and it has been a good investment. Sometimes you can find a set on craigslist cheap. Also take in mind where are you going to get the tanks refilled?
Old Apr 10, 2008 | 11:44 AM
daveengelson's Avatar
daveengelson
If you purchase a used unit, suggest it be thru a welding supplier, don't want to be saddled with tanks that are useless. I went thru receipts from 01 and the cost for the tanks were $145 ea. and according to receipt, tank size for oxy. (M) style, and the acetylene (#4), have no ideal if standard tank classification, they are both approx. 4' high. The Victor oxy/acyl package, included cutting torch, and 3 tips, hose, etc. $200, with the cart, another $60. Purchased unit thru welding supplier who also provides air, not sure, perhaps they all do. Found the unit can set for months at a time, purchased of a MIG, now can set even longer, so chose the package where tanks are exchanged and I pay for the refill. Another option would be to rent for small fee. Find unless one has experience, which I do not, for auto body repairs; floor pans, quarter panels, etc. the oxy/acyl setup has its limitations. Anyhow, had an urge to chime in.
Old Apr 11, 2008 | 04:48 AM
tjc transport's Avatar
tjc transport
i ain't rite
for that kind of money, i would just toss in an extra hundred or two and buy a 50 amp plasma cutter.
Old Apr 11, 2008 | 01:28 PM
jjlogue3's Avatar
jjlogue3
I second that if you are just planning on using it for cutting a plasma would be cheaper in the long run because you don't have to pay for the gas (Oxy, Acyl, Propane).
Old Apr 11, 2008 | 07:29 PM
LiftTech's Avatar
LiftTech
Thanks for the advice, y'all. I'm going to stop by the local welding supply shop and see what they can do for me. I'll definitely look into the Harris torches, too.
I'd love to have a plasma cutter, but right now I'm just getting started buying 'shop tools' and a torch would be far more versatile. A plasma cutter isn't too good for heating up stuck nuts and bolts.
Thanks all!
Old Apr 12, 2008 | 12:46 PM
rebocardo's Avatar
rebocardo
You can't weld or shape metal with a plasma cutter either. Quickest way to make a bend in tubing for a bumper is to heat it up and bend it around a 15" rim.
Old Apr 12, 2008 | 02:54 PM
Krochus's Avatar
Krochus
I third the plasma cutter. Torch sets are too costly in the long run to pay off for the DIYT'er I use some pretty nice flame cutting equipment at work every day of the week bug-o, harris, victor and oxweld you name it I've used it. But were I in your position I would buy a good plasma cutter 7 days a week and twice on sunday. Torches at home always seem to have a nasty habit of being out of either gas or oxy just when you need them most
A $20 bernz-o-matic works fine for that.
I've been wrenching on the side for years, so far my big bertha wratchet with 24" handle has been sufficient
WOW! what a great way to make a cool looking bumper with no strength whatsoever. Just make shure you dose the red hot steel with cold water to bring your bend up to it's full potential for brittleness.
please tell me you've never built a cage
Old Apr 12, 2008 | 10:08 PM
427SOHC's Avatar
427SOHC
Dont forget to check Ebay, I got lucky and bought a nice set of dual stage regulators for 49.72 with the airco name 2 years ago.
These dual stage ones new are around 300.00 for each regulator.
I already had the torch and hose, I purchased a set of "Q" sized tanks at the welding shop for 120.00 each filled.
I also picked up the Henrob/Cobra kit that was on demo at the F100 show in Knoxville last year, this kit was some of the best money I have spent on tools for a long time and I have used it alot.
There is one for sale on Ebay right now with 12 hours left, the link is below.
Henrob MK IV OXY-ACETYLENE welding-cutting torch - eBay (item 230239859785 end time Apr-13-08 08:40:22 PDT)
Old Apr 12, 2008 | 10:43 PM
RV67's Avatar
RV67
8th Gear
I got real lucky 2 years ago when my wife went to a garage sale and found a used torch set.It was a complete set-up w/ Smith torch and red bud tip and different size brazing tips,Full size tanks that were 3/4 full......all for $200.The seller held them for me until I got off work to look at them.Need-less to say I was estatic.
Old Apr 13, 2008 | 09:49 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Go to Ebay for your torch sets and tanks. I got 80cu-ft tanks for about $280 shipped, and Victor SuperRange II torch set for $247 shipped.
Be careful with the Victor torches. They are cheaply made, and will crack if you over-tighten the valves or hoses. Mine did I'm going to replace mine with Smith's someday...
Old Apr 13, 2008 | 11:31 PM
brh1969's Avatar
brh1969
OVER TIGHTENING being the key word there.There is nothing wrong with Victor.In my experience Victors last longer than Smiths do.Ive probably used 50 different sets of torches 3/4 of them were Victors and the rest were Smith/Harris.No torch set lasts very long when you are over tightening stuff,this happens at my work alot.Just cant seem to get people to understand that brass on brass doesnt take 800 ft lbs to seal.
Old Apr 25, 2009 | 11:34 PM
Skullonarm's Avatar
Skullonarm
I think my two sets of Harris cutting outfits have a nicer flame than the victor's. you just can't use them as a welding hammer like the Victors.
