Power window failure- 1990
Old Aug 20, 2009 | 05:05 PM
michaelbrainardatwor's Avatar
1990 F350
The right front power window regulator has failed. The motor runs, the window will "hop" a bit but will not raise. I can pull it up by hand and it will stay...it will lower, but not come back up.
Do I need to replace the entire regulator, or just a gear?
Old Aug 20, 2009 | 05:59 PM
skaterbro's Avatar
skaterbro
That's gonna be the roller pins in the window motor. No need to remove the whole regulator assembly, just the motor itself.
Seems to be happening a lot lately.
Old Aug 20, 2009 | 06:48 PM
Virto's Avatar
Virto
Those stupid plastic parts are constant failure points, in fact, the exact problem plauged my '90.
Numberdummy will tell you just how often those damn things failed. You should be able to get them at the dealer (don't) or the Help! section in most autoparts stores.
Old Aug 20, 2009 | 07:44 PM
skaterbro's Avatar
skaterbro
I've been a victim as well. You can get them at any parts store but i do know at kragen it's 8 bucks for the three pins to do one window motor. Part #74410
Old Aug 20, 2009 | 07:46 PM
andym's Avatar
andym
Cheap parts generally don't last as long, as a rule. I spent a couple extra bucks and went to the dealership to get the gear rebuild kit. This way it will last as long as the original did, and 20 years is pretty good for some plastic gears.
Old Aug 21, 2009 | 08:39 AM
Thanks for the info!
Old Aug 21, 2009 | 11:34 AM
Alvin in AZ's Avatar
Alvin in AZ
Yeah but. :)
In this case Dorman/Motormite was the outfit that made the parts for Ford to start with...
http://www.outdoorpros.com/Prod/Dorm...51426/Cat/1271
In my case the gear was like new, only those break-away torque-limiters were messed up.
(rear window, '91 Bronco)
Alvin in A
ps- You guys, like Bill the ND, can bad mouth the design all
you want, but don't see any of you making a better one. ;)
pps- The way I see it, they could have weakened the motor
etc -or- provided a release when things went wrong with a
powerful system, take your pick. ;)
Old Aug 21, 2009 | 11:57 AM
1Aauto's Avatar
1Aauto
Former Vendor
Originally Posted by michaelbrainardatwor
1990 F350
HI Mike,
I have a new window motor in stock for your application.They're NEW not Rebuilt ones.
Ford Truck Window Motor
We also have just the plastic gear that goes between the window motor and regulator if that's what you need.
Window Regulator To Motor Gear
Old Aug 21, 2009 | 01:57 PM
Alvin in AZ
Originally Posted by 1ATony
HI Mike,
Hey Tony, turn on your caps-lock. LOL :)
Alvin in AZ
Old Aug 21, 2009 | 03:17 PM
1Aauto's Avatar
1Aauto
Former Vendor
Alvin in AZ
I was to lazy to. have a great weekend guys.
Old Sep 1, 2009 | 07:33 AM
djbcs's Avatar
djbcs
Had the same problem with my 92 window. Luckily had a friend with an 87 rusting away in his backyard, tested the motor (lo & behold - it worked) which we pulled (motor & regulator -30 minutes). After replacing same into my truck - works perfectly, tested the removed motor. Worked great UNTIL it was re-assembled with the regulator, then it barely moved. Have a feeling that if the motor brushes were replaced, it would work again as intended. (Am checking around local area to see if this can be fixed cheap, just in case I need a back-up motor.)
Old Sep 4, 2009 | 01:51 AM
gpedens's Avatar
gpedens
window woes
have had the same problem. make sure you clean out all the old grease and broken bits of those 3 rollers or drive pins. I made mine from 1/2 dia nylon rod turned to 7/16 dia and 7/16 long. Be sure to use a good replacement grease. that was several years ago.
dionysius
Aug 21, 2017 07:31 AM
Troop4Christ
16
Jun 25, 2017 10:29 AM
bigcrunch
Jun 13, 2017 06:24 PM
thaipokey
Mar 20, 2017 03:15 PM
cypressdelight
Apr 24, 2016 01:55 PM
