X on the Tree
Old Aug 22, 2009 | 11:27 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I've owned one 4-sp column shifter, on a '60's Mercedes. Needless to say, it was over-engineered but had a wonderful feel. It had a cast shifter gearbox on the bottom of the column with brass gears and was totally sealed, and oil-filled. Absolutely wonderful but nothing that would help here.
I'd be curious to see the Econoline 4-sp columns shifter mechanism. If you look at how the 3-sp column shifter works, you could just add a third shifter lever at the bottom of the column, but the throw at the shift lever fore-aft (across neutral) would probably have you hitting the dash on one end and the steering wheel on the other. To avoid that you'd have to use a smaller diameter selector pin, or more of a lever ratio up top.
The better approach might be to do what FWD cars do with their floor shifters: use two cables with a bellcrank on one motion to operate a single-rail shifter on say a T5.
Old Aug 23, 2009 | 08:16 AM
AXracer's Avatar
AXracer
Ford offered an OD option on sedans in the mid fifties that was activated with a switch (cable?) under the dash, so you had 3 on the tree + switch. The trannys/OD units come up on ebay once in a while.
Old Aug 23, 2009 | 11:11 AM
Blue50F-1's Avatar
Blue50F-1
That sounds like a real option right there. I've never dealt with a FWD manual, but I'm sure there are plenty of pics out on the net that could get a guy in the right direction. Thanks!
That's another good idea. I'll keep an eye out.
Thanks again guys.
--James
falcain
Jan 11, 2015 10:54 PM
dalefurrow
Mar 4, 2013 10:58 AM
Blue50F-1
Aug 20, 2009 02:18 PM
TimRob
1983 - 2012 Ranger & B-Series
Aug 18, 2005 08:02 PM
dj9124
Dec 1, 2003 08:05 PM
