Loose column shift lever
Old Aug 17, 2005 | 02:32 PM
TimRob's Avatar
TimRob
Hey all,
I don't know if this is a bonified problem but the shift lever on my steering column (automatic, not manual) is fairly loose, quite a bit of play in it. Is this something I should be concerned about? Is it an easy fix? I've checked the outside of it and it looks like I'd have to take the column apart to get the shift lever boot off to tighten anything. Is this pretty much what I'm looking at having to do?
Thanks in advance!
Tim
Old Aug 18, 2005 | 08:02 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
I think there's a pin that holds the lever into the column.. it may be coming out or the holes in the shifter may be "wallowed" out.
You might be able to access it by removing the plastic covers around the column..at least you can on the newer ones
good luck
Jersey devil
Dec 10, 2016 12:22 PM
youngblood1989
Aug 17, 2016 05:13 PM
66f100project
Jun 9, 2016 06:58 PM
Keepitrunnin
Feb 9, 2015 08:02 PM
Big Sky
Feb 5, 2013 01:11 PM
