HPX pictures?
Old Aug 19, 2009 | 12:47 PM
79f-250custom's Avatar
79f-250custom
ooooooooo i c now you remove the plugs in the head... if i wen to a hardware store and bought some fittings and some steel line could you make this yourself?
thanks guys
Mitch
Old Aug 19, 2009 | 02:01 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
Originally Posted by Brown Falcon
Is there much of a difference between the hard line and the braided line? They both do the same thing. Is one better than the other?
I can't complain about the price I paid for mine though...
Well teoretically is better the braided line, because the intention of the line is to ensure that the high pressure oil rails receive the same amount of high-pressure and according to Dale (Tymar) is better if you connect the rails in the posterior plug of each rail (7 to 8), but as it that almost impossible because the tubro and the intake hose, so you have to connect the line in the next one plug (5 pass side to 6 in drivers side), and with the hard line it goes from 5 to 4, and the other advantage is that you take out the 90* stock fitting connector from the orginal drivers line in #6 plug, and the oil flow better through a straigth connector (which comes with the kit) that you move to plug #4.
Originally Posted by wildstang
I think with the braided line it is recommended to replace every few years, the hard line is probably just watch for rust holes.
Also acording to Dale and others, the braided line is made with the same material than the stock oil lines, and till I know, nobody recommend to replace them every few days, most of our OLDER PSD has the originals.
thanks guys
Mitch
I wont recommend to do yourself, because the high oil pressure there could be VERY DANGEROUS. and the price of the aftermaket lines are not expensive
Old Aug 19, 2009 | 02:27 PM
Neal 97 250's Avatar
Neal 97 250
the fittings are hard to find. O-ring to flare or vibration style fittings.
Riffraff Diesel has some absolutely awesome flexible ones. They are extremely high pressure rated and wrapped in a very high heat fire proof sleve. Top notch IMO.
Old Aug 19, 2009 | 03:01 PM
Brown Falcon's Avatar
Brown Falcon
Originally Posted by BlueMule
I just noticed you still have the red intake boot going to the turbo. Have you checked it lately? Most of them were replaced long ago because they didn't last. Take a look at the area where it clamps to the turbo. They usually rot and crack on the bottom and let unfiltered air into the turbo.
Where can I get a new intake boot? And how much are they?
Old Aug 19, 2009 | 03:17 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Buy this one, is the chepeast I have found and direct fit to change the orange boot.
http://intakehoses.com/Merchant2/mer...egory_Code=FPM
But if you are going to make the CCV mode buy the black one.
Old Aug 19, 2009 | 09:18 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
I know I have read it somewhere, but maybe it was referencing a rubber hose.
Old Aug 20, 2009 | 01:15 AM
kupiec20's Avatar
kupiec20
now what does this mod do again?
Old Aug 20, 2009 | 07:58 AM
Brown Falcon
The HPX basically equalizes the High Pressure Oil between the two heads. Supposed to smooth it out a little, let all the injectors fire better. What I was told is that the #7 cylinder especially tends to get less oil.
Old Aug 20, 2009 | 02:36 PM
BlueMule's Avatar
BlueMule
That would be #8. The firing order is 1-2-7-3-4-5-6-8. Because 6 & 8 are both on the same side 6 uses the oil pressure and then 8 fires before the pressure has time to recover, with the crossover line some of the pressure bleeds over from the other head to assure that 8 has as much pressure as possible.
The problem with the #7 injector was on the souperdooty trucks with their dead head fuel systems. The #7 would get shortchanged on fuel and would "cackle"
exbxtoy
46
Sep 13, 2016 01:25 PM
Km1210
82
Apr 27, 2016 02:52 PM
Anthony Giovino
Ford Truck Parts for Sale
Feb 24, 2016 01:56 PM
BuckHammer
43
Oct 5, 2011 01:49 PM
cutlass
37
Sep 8, 2010 07:51 AM
