Debating on getting the HPX
Old Oct 25, 2012 | 10:15 AM
Km1210's Avatar
Km1210
I'm a little stumped on whether or not I want to get the HPX(high pressure crossover). I do believe that it does what it's supposed to, but is it another place to have a leak?
Guys that HAVE them, I would like to hear your opinions. Thanks.
Old Oct 25, 2012 | 10:22 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Had mine a few years with no leaks.
Old Oct 25, 2012 | 10:34 AM
Texas Chain Ring's Avatar
Texas Chain Ring
Any performance benefit to doing this?
Old Oct 25, 2012 | 10:38 AM
DP-TunerSales's Avatar
DP-TunerSales
From the testing Jody did on his personal Excursion, the engine was smoother without it.
Old Oct 25, 2012 | 10:40 AM
empiretc's Avatar
empiretc
8 years, no leaks. get the SS one for piece of mind.
Old Oct 25, 2012 | 10:46 AM
timmyboy76's Avatar
timmyboy76
i have no "real" data to prove its worthyness, but no leaks here after 2yrs. Only downfall, is, it gets in the da$# way when removing the turbo...
Old Oct 25, 2012 | 10:52 AM
ToMang07's Avatar
ToMang07
I have one, a couple years now, no issues. I do have the rail plugs in my glove box should it ever start to leak. Let it cool, remove, and re-plug it.
I definitely like that it allows the rails to be more equally pressurized, IE reading both sides with the ICP.
Old Oct 25, 2012 | 10:56 AM
Texas Chain Ring
The truth shall set you free? Thanks.
Old Oct 25, 2012 | 10:58 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
ive got one of the one piece crossover's ill sell ya for 30 shipped.....i had to go to the hose kind after switching to an h2e turbo....nothing wrong with it.....lmk....
Old Oct 25, 2012 | 11:01 AM
indyF-350psd
way too many variables in that comment for it to be a freeing statement.....after putting in my swamps singles and adrenaline with the check valves removed and the hpx removed i quickly put the hpx back in because it ran and idled like crap.....much better with the crossover in......
Old Oct 25, 2012 | 11:02 AM
indyF-350psd
if you check out the graph on strictly's website you will see it even out the hpo pulses in the rails.....not really a performance thing but a solution to fix an inbalance.....
Old Oct 25, 2012 | 11:08 AM
ToMang07's Avatar
ToMang07
Yup. You have 2 rails....one on each bank. But only 1 pressure sensor.
Old Oct 25, 2012 | 11:09 AM
bdpotts's Avatar
bdpotts
same here. no leaks, noticed instant sound difference with #7 & 8 cylinders... no maintenance issues whatsoever. go for it! you'll like it.
Old Oct 25, 2012 | 11:19 AM
Texas Chain Ring
and if I leave my alone, what's the outcome? Currently runs with a chip, injectors and turbo and exhaust in the future. What imbalance?
Old Oct 25, 2012 | 11:38 AM
miller_feed
Could be if #8 injector is not getting enough oil psi. I didn't notice any improvement dough.
