Truck still running rough and getting code for ICP 1211...I took the ICP off my 2001 to see if it fixed it but didnt..When I pulled it out could hear pressure releasing.. If I unplug ICP to see if it runs better the motor dies..Do I need ICP ??
when I pulled the ICP it let off pressrue and put back in the truck ran better for a short period..then it started acting up again..the code also said was getting to much pressure.. Will check out your 2 links...ty
Just put on new ICP yesterday...still not running good plus I still have same code coming up.. How u make sure HPOP is full ?? dont see any place to check it on a 96 7.3..
thxs
To check the HPOP oil level unscrew the hexagon screw head on top of the HPOP reservor. The oil should be 1/4" from the top of the hole.
