CEL no code???
Old Aug 15, 2009 | 08:02 PM
BeauHymel's Avatar
BeauHymel
CEL no code???
I have a 2002 Expedition with a 4.6L. Last week the CEL came on and it started to run rough. When I connect my code reader it does not come on and I can get no codes. The code reader will work on mt 2005 GMC. It haso also worked on the Expedition in the past. Does this indicate I may have a connector problem with the connector? I plan to go to Autozone and see if they can read any codes tomorrow. Is the DTC fused or something? THANKS for any ideas.
Old Aug 15, 2009 | 09:33 PM
Oldtrucknut7077's Avatar
Oldtrucknut7077
It may be a coilpack/cop going bad. If its missing isn't recongnized by the computer, it won't throw a code.
Old Aug 16, 2009 | 08:38 AM
projectSHO89's Avatar
projectSHO89
Check the fuse for your cigar lighter. The diagnostic port is on the same fuse.
If the fuse is blown, most scanners won't communicate since they draw operating power from the port.
Old Aug 16, 2009 | 05:52 PM
BeauHymel's Avatar
BeauHymel
Thanks for the quick reply. You are correct, hte fuse was burnt. I swapped out the fues and I can now read the code. I have a miss fire on cylinder #4. I had this problen in the past and cleared it by changing out the COP boots. I hope it is that cheep this time. Thanks again.
Old Aug 20, 2009 | 09:37 PM
BeauHymel's Avatar
BeauHymel
I decided to run some seafoam through the engine. This seems to have cleared up the miss and no CEL yet.
Old Aug 22, 2009 | 09:51 PM
99ExpyProblems's Avatar
99ExpyProblems
It will be back...It might take it a bit, but you'll be either putting in new plugs or a new COP.
Old Aug 30, 2009 | 11:23 PM
BeauHymel's Avatar
BeauHymel
Well its back. Should I just change the COP and plug on cylinder #4, or should I do all 8 COP's nad plugs? THANKS again.
Old Aug 31, 2009 | 01:22 AM
alloro's Avatar
alloro
Have to given thought as to a possibly bad injector? Your best bet to avoid spending for wrong parts is to swap the COP, plug, and injector, one each to another cylinder (each to a different cylinder). When the misfire code moves from #4 to one of the other cylinders, you've found the bad component. Make sure you write down which of the three components went to which cylinder.
Old Aug 31, 2009 | 06:34 AM
99ExpyProblems
I would not switch all of them around. IMO, #4 Coil is the hardest one to get to, but I would switch #3 and #4. Also, I would never change just 1 plug on my Expy. If you are anywhere near 100,000 miles, I would change all of the plugs. Then, if you really wanted to, you could switch the boots around. I use Autolite Double Platinum plugs. I think APP103. They must be DOUBLE PLATINUM or OEM Motorocraft plugs. Also, use dielectric grease inside the boots and on the actual electrical plugin. Be generous!
Use anti-seize on the plug threads and there is a trick to getting the plugs in. Use 2 spark plug sockets. 1 with the rubber insert, 1 without. Place the plug in the socket just enough for the rubber to grip it, then start the threads. Get about 3 turns on it, and then use the socket without the rubber insert to finish the job. I found that doing it this way makes the job easier.
Old Aug 31, 2009 | 09:40 AM
99ExpyProblems
Sorry, I would switch #4 and #1. That way, if #1 misfires, then it is very easy to change out.
38Chevy454
General Automotive Discussion
Nov 17, 2011 10:47 AM
drivembig
Jan 13, 2010 06:49 PM
jima
Dec 14, 2008 02:54 PM
b2trausch
Apr 1, 2007 08:36 PM
roybus14
Computer Chips & Tuners
Feb 3, 2007 10:25 AM
