No power at test connector???
Old Mar 25, 2007 | 08:51 PM
b2trausch's Avatar
b2trausch
My daughter's 2000 Merc Mountianeer had the CEL come on yesterday. As she lives about 60 mi away, I asked here to swing by a local parts store to have the codes read.
She called and said that the guy at the parts store said that there was no power coming from the vehicle at the test connector. I did verify the following from her.
1) The power was "on" on the code reader
2) The ignition switch was turned to "on"
3) The parts guy checked the fuse, and it's good.
Any ideas what I should check?
Old Mar 25, 2007 | 09:30 PM
aagitch's Avatar
aagitch
You could maybe have her try a different autoparts store incase the guy that hooked it up did something wrong.
Old Apr 1, 2007 | 08:36 PM
b2trausch's Avatar
b2trausch
Remove and replace parts guy. Read codes just fine
Aagitch, you were right. My daughter came home this weekend, and I hooked up the code reader and it read the codes just fine.
I pulled a P0455 (EVAP leaking) code. I've cleared the codes, and it hasn't returned. I had asked my daughter to check the gas cap, which she did, but didn't notice anything abnormal, but the CEL was still on unitl I cleared it. I was wondering if the code not clearing by itself is normal for this type of code, or is there something else that I need to check for. If so, I'm open to suggestions on what else could commonly cause this code to appear.
Thanks for your help
79f150
23
Aug 15, 2013 10:28 AM
nuke tech
Aug 8, 2013 09:05 PM
diverstroker
18
Oct 4, 2011 04:10 PM
Supercab
1983 - 2012 Ranger & B-Series
Apr 25, 2011 09:28 AM
jennkent5454
1997 - 2003 F150
Jan 12, 2010 08:34 PM
