Computer Chips & Tuners
Code Readers
Old Jan 31, 2007 | 11:59 AM
roybus14's Avatar
roybus14
Code Readers
Fellow Ford owners,
I am interested in purchasing a code reader to helpe diagnose problems with my '04 Expedition XLT. Can you recommend any good code readers and does Ford use the "CAN" protocol on their new trucks and SUVs? I've investigated a couple of code readers and some don't work if "CAN" protocol is being used on your vehicle.
Thanks in advance for your help.
Old Feb 1, 2007 | 07:39 AM
projectSHO89's Avatar
projectSHO89
Yes, you DO need CAN protocol on your 04.
Inexpensive code readers are available for as little as $65 at WalMart that will read codes, reset codes, check OBDII readiness monitors, and not much more.
A decent, capable scanner that can also display freeze frame and real-time data and manufacturer-specific codes will run $300-400. If you want to be able to read supplemental systems (ABS, SRS, etc), prices run from $700-2500.
If you have an available laptop, interfaces with software start around $125-150 and go up from there.
Steve
Old Feb 2, 2007 | 09:47 PM
ReAX's Avatar
ReAX
I have had good luck with B&B's Autotap. I haven't tryed it with a CAN yet, tho. As soon as sniper releases thier Recon datalogging suite, we'll know if it does codes (I sure hope it does.)
Old Feb 3, 2007 | 10:25 AM
jdadamsjr's Avatar
jdadamsjr
1) Autozone will read your codes for free...
2) IF you insist on spending the money on a code reader, why not get a programmer ? 99% of the good programmers have built in code readers.... then you get the benefit of more "efficient" power
PaxtonShelby
Nov 12, 2014 03:58 PM
steveamann
13
May 5, 2013 03:33 PM
Ecarlton1991
Aug 14, 2011 06:20 PM
bkuuz1
Jan 11, 2010 12:02 AM
Dependable
Aug 22, 2006 10:50 PM
