shifter Q.
Old Aug 15, 2009 | 07:53 PM
93 mix 'n match's Avatar
93 mix 'n match
shifter Q.
hi! the boot for my shifter is missing and i just bought a autozone hotrod style boot that im gonna rig up to it. my problem is the shaft starts out small then gets gradually thicker with some sort of rubber/plastic then goes to bare metal towards the bottom. is there any way to remove this?
sorry i would take pics but its 9:00PM here
Old Aug 15, 2009 | 09:17 PM
Diesel_Brad's Avatar
Diesel_Brad
What year is your truck? It is a 5spd? If so, no. That fat part of the shifter(1 3/8)Where the stock boot seals to the shifter is 1 1/4. Maybe if you unbolt the shifte from the trans then put the boot on then instal lthe shifter back on the trans
Old Aug 15, 2009 | 09:29 PM
93 mix 'n match
93 5 speed. ill take pics tomorrow but it dosent look like ill get this thing on without some serious cutting to the boot. i got one of those hotrod style ones. i know i was gonna have to cut anyway but this sucks even more.
Old Aug 15, 2009 | 09:59 PM
Diesel_Brad
just spend the$$ and buy the correct one or go to A JY and get a used one
Old Aug 15, 2009 | 10:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F5TZ7277BA .. Shift Lever Boot / 1985/96 F150 M5OD.
MSRP: $58.98 // FTE sponsor Y2KFORDPARTS.COM price: $42.47.
Old Aug 15, 2009 | 10:29 PM
93 mix 'n match
ya screw that! like im dumping 50 bucks on a stock rubber boot! ill hack the hell outa this thing till it fits.
Old Aug 15, 2009 | 10:36 PM
Diesel_Brad
Old Aug 15, 2009 | 10:48 PM
93 mix 'n match
Originally Posted by Diesel_Brad
you wait. it'll look good.
theres no way in hell im going to spend $50 on some little rubber thing.
Old Aug 16, 2009 | 10:45 AM
waynaferd's Avatar
waynaferd
Too remove the shifter take the nut off of the pass. side, put on driver's side and tighten, and that'll pull the pin out so you can take off the shift lever.
I'd spend $5 at a J/Y myself for an OE one.....
Old Aug 16, 2009 | 01:19 PM
nat13_3's Avatar
nat13_3
Or you could just use your POS boot and put a towel around it... Then no tranny whine and road noise leaks in and you have a towel for whatever apllications you may think of.
DanielT28
Jul 10, 2014 07:43 PM
90turbo1
Jul 6, 2014 02:49 AM
Cowgal94
Mar 11, 2014 11:42 AM
napass2004
Jul 9, 2013 08:17 AM
ericolicious
Dec 30, 2004 01:56 PM
