Sponsored by: Auxito
Moog ball joint ?
Old Aug 15, 2009 | 10:43 AM
ford1/2ton's Avatar
ford1/2ton
Moog ball joint ?
I'm getting ready to change my upper and lower ball joints on my 99 f150 and have a ? about the lowers.
I'm going to use Moog ball joints and was wondering if I can press them in the original lower control arm or do I have to buy the Moog control arms?
Thanks in advance.
Old Aug 15, 2009 | 03:21 PM
bones2000's Avatar
bones2000
i have a 2000 f150 and replaced the uppers and pressed the lowers
Old Aug 15, 2009 | 03:51 PM
ford1/2ton's Avatar
ford1/2ton
Thanks for the reply.
Old Aug 15, 2009 | 08:30 PM
papajoemrt's Avatar
papajoemrt
i don't recall moog making the lower control arms. they need to be pressed out then pressed back in. when i did mine they were fairly easy with aero-kroil or pb blaster. a nice sized hammer and solid piece of round steel that fits in the ball joint and a few good blows will pop it out. then an extremely large c-clamp (i'm talking industrial sized that weighs a good 30 to 40 pounds and over a 1 inch sized screw in it) and great feat of strength to press them back in.
Old Aug 15, 2009 | 09:22 PM
steve(ill)'s Avatar
steve(ill)
Auto Zone will let yo borrow an industrial C-clamp ball join press if you get the Moog joint there. you press them out and press them back in. its not difficult all all if you got the press. there is a c-clip on the back side, take it off first. Upper joints come with the amr for about $80 each.
Old Aug 16, 2009 | 07:10 AM
vze2sgxa's Avatar
vze2sgxa
Moog lowers (got from Autozone) fit fine on my 2000 expy (more or less the same truck as F150), and Autzone rented me the press kit and a set of the really large sockets (one of them fit the front axle nut - 35 or 36 mm I think). I have a 4x4 so I removed the hub for both sides. I also replaced the outer tie rod ends with Moogs. No problems.
timf150
Sep 30, 2015 10:06 AM
Driton
1983 - 2012 Ranger & B-Series
Sep 4, 2014 07:37 AM
Snow Descent
1997 - 2003 F150
Jul 9, 2014 08:54 AM
DanK5
1997 - 2003 F150
Apr 21, 2011 09:48 PM
Ryan50hrl
2004 - 2008 F150
15
Mar 21, 2010 09:57 PM
