2001 Edge Tranny Flush
Old Aug 13, 2009 | 01:33 AM
Desert 4x4's Avatar
Desert 4x4
Hi Guys,
I am going to flush my brother tranny this weekend and I need to know how much fluid the tranny holds. 2001 Ranger Edge 4.0 w/ 5 speed auto. Is there a tranny flush procedure for this tranny, or can I use the same procedure as a 4R100.
Old Aug 13, 2009 | 07:13 AM
pawpaw's Avatar
pawpaw
From our "Tech Info" thread, here is how I do it on my 99 4X2, 5R55E tranny.
EDIT URL: https://www.ford-trucks.com/forums/6...-pump-out.html
Look in the owners manual for the tranny capacity, if he has a 4X4, it'll likely take a little more fluid, as it has a deeper tranny pan & it'll take a different filter with a longer snout on it.
My 99 4X2 5R55E tranny system capacity is 10qts, so I buy a 12qt case, run an extra qt through it on the pump out, to allow for torque converter mixing & use the last qt to top up with.
Before raising the vehicle on stands to drop the pan, if you'll First disconnect the tranny return line at the cooler as outlined in the link & idle the engine with the vehicle Level, it'll remove most of the old fluid from the tranny pan & make the pan drop easier & Much less messy.
Level the vehicle after cleaning the pan & magnet & changing the tranny filter & reinstalling the pan, then refill the pan with the same amount removed & continue idling the engine for 15-30 seconds at a time, to continue the pump out, 1-2 qts at a time & top up, (so you don't run the tranny pump dry), until the full system capacity has been removed. This will get most of the old fluid out of the valve body, torque converter, cooler & lines, without running the tranny pump dry, which it'll appreciate!!!!
Let us know how it goes.
Last edited by pawpaw; Aug 13, 2009 at 07:21 AM. Reason: URL link didn't copy right.
Old Aug 13, 2009 | 08:16 PM
Desert 4x4's Avatar
Desert 4x4
pawpaw thanks for the help
ssharber
6.4L Power Stroke Diesel
21
Apr 23, 2012 08:21 AM
68 351 bronc
Nov 10, 2010 04:31 PM
Beaned
Aerostar
Dec 11, 2008 10:48 AM
tndiesel
Aug 25, 2008 12:52 PM
nissanjon
Jul 8, 1999 10:40 AM
