Tranny Flush ?
Old Aug 12, 2009 | 08:51 PM
6litrefan's Avatar
6litrefan
Tranny Flush ?
Hey guy's just had my torqshift tranny flushed at a local reputable Ford dealership...my question is on the receipt it states they used a "PF5 Service kit-$19.31" it does not state a filter was replaced.....does anyone know what this PF5 service kit is???.....isn't the PF5 the machine they use to flush the tranny?...I shoulda ask them but i just wanna make sure i have a new "external" filter.....any help appreciated guys!
Old Aug 12, 2009 | 09:05 PM
06silvercrew's Avatar
06silvercrew
The PF5 maching is a fluid exchange machine made by BG products. The service kit consists of a "cleaner" and then a "conditioner". Very good products, I have used all the BG products for years and have had excellent luck. You will have to ask them if they changed the ext. filter or not. If not its no bug deal you can do it yourself.
Old Aug 12, 2009 | 09:10 PM
6litrefan's Avatar
6litrefan
Well i know I have changed it before myself my question is, can i change it without loosing alot of fluid?....I shouldnt loose too much right?
Old Aug 12, 2009 | 09:24 PM
06silvercrew
Shouldnt loose too much, maybe pick up a couple quarts of fluid just to be on the safe side before you change it?
Old Aug 12, 2009 | 09:48 PM
hi mile ford's Avatar
hi mile ford
unless your truck is a d max or a new 6.4 twin turbo your tranny has an internal filter which cant be changed unless you want to drop the pan. the flush will get the filter 95 percent clean so you can flush it two or maybe three times then i would change the filter. i usually go fourty thousand on the flushes.
Old Aug 12, 2009 | 11:44 PM
1957F100's Avatar
1957F100
Wrong...The 6.0 pretty much just has a screen in the tranny pan...the actual filter is a external filter.
Old Aug 13, 2009 | 05:52 AM
Rob.D's Avatar
Rob.D
Or you can upgrade to the 08 Ford tranny pan and internal filter. I got both sitting in a box waiting to turn 30,000 on my 06. From what I've read the external filter is actually a bypass filter.
Old Aug 13, 2009 | 08:23 AM
albran's Avatar
albran
The dealer (probably) didn't change the external filter, they're missing a really easy money maker but that's the way they do it.
I did a search for you, it's a really cheep easy DIY (22MM socket and a really hard pull ((it will come off)).
https://www.ford-trucks.com/forums/s...archid=1050139
ab
Old Aug 13, 2009 | 08:33 AM
devildog12210's Avatar
devildog12210
I changed my tranny fluid and both filters right after I bought my truck. It was extremely easy. I had a hell of a time getting that external filter housing off though.
Old Aug 13, 2009 | 08:00 PM
06silvercrew
quick bump with an impact makes it much easier. I nearly tore mine off the frame and it wouldnt come off, quick bump with the gun and off it came.
Old Aug 13, 2009 | 10:12 PM
hi mile ford
my bad in my time in a quick lube shop i dont remember seeing many 6.0s with a external filter im sure they have them what year did they start with the external
Old Aug 14, 2009 | 01:59 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
They started with the first 6.0L in 2003 and continued for every 6.0L built. No 6.0L automatic truck left the factory without an external filter.
That's why one should not get important work done at a quick lube shop.
heartnurse73
Apr 4, 2013 08:50 AM
StorkPKP
Dec 8, 2010 04:03 PM
megawatt00
53
Nov 24, 2009 11:23 AM
mgood
May 28, 2009 02:53 PM
Kai
25
May 1, 2003 04:05 AM
