aluminum drive shaft
Old Jan 21, 2002 | 11:44 AM
tapenick's Avatar
tapenick
Anyone know of a source for an aluminum drive shaft for a 97 4x4?
Old Jan 22, 2002 | 06:47 AM
98expeditionXLT's Avatar
98expeditionXLT
I'm curious as to why you would want an aluminum driveshaft.
Old Jan 22, 2002 | 09:17 AM
tapenick's Avatar
tapenick
Post aluminum drive shaft
Ford is recommending that anyone repairing a three joint driveshaft switch to a two joint. I've had great experiences with aluminum driveshafts in the past so I figured if I was switching I'd go aluminum.
The guy @ the local drive train shop recommended not going aluminum... he cited strength as an issue in a truck that big. Funny that StangBangers with > 500 HP run them without problems.
He also recommended fixing the factory shaft so I just bought a new centering bearing and did the quick fix. I'm still interested in following up on this issue... I'm checking availability on two joint shafts out of later models in junkyards now. Anyone know if / when they switched? The related TSBs were written in 97.
Old Dec 8, 2002 | 11:58 PM
ratoronnos's Avatar
ratoronnos
i have an aluminum drive shaft i will part with for a ford i dont know what truck it is for but i know it is a ford and the measure ment from center to center of the holes on drive shaft is 55.5 inches if it would work for you i can send you pictures.
email me at raptoronnos(No Email Addresses In Posts!) if you are interested
Old Dec 9, 2002 | 01:18 PM
PaulC's Avatar
PaulC
JRS2
May 26, 2016 06:15 AM
raven3
2015 - 2020 F150
Oct 23, 2015 06:46 PM
raven3
2015 - 2020 F150
Oct 17, 2015 09:07 AM
raven3
15
Jun 20, 2014 08:34 AM
hllon4whls
2004 - 2008 F150
22
Apr 11, 2012 02:21 PM
