Changed the antifreeze but.................
Old Dec 8, 2002 | 12:04 PM
1999XLT's Avatar
1999XLT
Now I get the sound of liquid swooshing around inside cabinet when I come to a stop or accelerate. It is coming from the heater core area. It didnt happen before I changed the A/F any ideas as to the cause or a solution? It is at the point of now it is annoying me. It is not loud it is just annoying.
Thanks.
Steve
Old Dec 9, 2002 | 11:56 AM
buzzard's Avatar
buzzard
That's weird, the heater core should completely fill-up when you refill the system.
Old Dec 9, 2002 | 01:18 PM
PaulC's Avatar
PaulC
[updated:LAST EDITED ON 09-Dec-02 AT 02:18 PM (EST)]WITH A COLD ENGINE, remove the cap from the overflow tank, start the engine, turn the HVAC control to "HEAT" and the temp control to the hottest position (fully clockwise). Let the engine run for ten minutes to allow the thermostat to open, gently revving the engine up and down occasionally. This should "burp" the system. If you have rear heat, turn that temp control to the hottest position as well.
Don't leave the vehicle alone while the cap is off.
Old Dec 9, 2002 | 01:20 PM
Jerm's Avatar
Jerm
