Drive shafts,one section/two sections
Old Oct 15, 2015 | 08:32 PM
raven3's Avatar
raven3
What configurations have one section drive shafts and two section drive shafts with intermediate support?
Are all the drive shafts steel or aluminum or mixed?
Old Oct 16, 2015 | 01:16 PM
GlueGuy's Avatar
GlueGuy
We have the 157" wheelbase (crew cab + 6-1/2' box) with 4x4. Our drive shaft actually looks like 3 pieces, and they are all steel. There is a support in the center & there are 3 universal joints. I say it "looks" like 3 pieces because the aft section has a flexible covering mid-span. I can't look inside w/o taking it apart, but I'm guessing it is some sort of splined expansion joint.
Old Oct 16, 2015 | 08:36 PM
raven3's Avatar
raven3
The two U-Joints at the TC make a CV(constant velocity joint),
The flexible cover is a boot that protects the splinted slip joint from dust and water.
Would consider this configuration, a two section design.
Old Oct 17, 2015 | 07:07 AM
rmccbride's Avatar
rmccbride
My super cab with 6.5 box 4X4 5L has a one piece aluminum one.
Old Oct 17, 2015 | 08:03 AM
Tom's Avatar
Tom
My 145" wheelbase CCSB has a one-piece aluminum shaft.
Old Oct 17, 2015 | 09:07 AM
raven3's Avatar
raven3
The Super Cab 6.5' box & Super Crew 5.5' box both have 145" wheel base and both incorporate a two section steel material with intermediate support bearing on XL trim as verified by actual inspection.
If the Super Crew 6.5' box with 156.8" wheel base has two section steel drive shaft . then the Super Cab 8" box with 163.7' wheel base must also have a two section steel drive shaft.
Recently found a regular cab with 6.5 ft box in XL trim level with 3.5l NA engine and physically verified the drive shaft is one section aluminum material with 122.4" wheel base.
The regular cab with 8 ft box has a 141.1"wheel base, steel or aluminum?
raven3
2015 - 2020 F150
Oct 23, 2015 06:46 PM
mini_blaine
Jan 30, 2014 10:20 AM
burton7.3
Jun 19, 2013 12:34 PM
aries1970
Jul 27, 2008 11:28 PM
DustinDLamb
Aug 9, 2006 11:31 PM
