It is indeed aluminum. Here is a pic from my camera phone.
Now remember, this is the 150 inch WB crew 4x4. Not as many of those around. My dad's is a scab 6.5 bed. Not sure of the WB. Both definately have the same rear, 3.55 LS.
Hllonwheels, how many miles do you have so far? Curious to see if the alum driveshaft makes a difference. You won't get the driveshaft "whip" you would get from a steel one. I am suprised Ford didn't try and go with a 2piece one with the center carrier bearing like in prior models. My 95 F250 has it, and so did my buddy's 79
Depending on the wheel base and the drive (4x4 or 4x2) some of the trucks do come in a two piece with a center bearing. The one piece (if it's a long shaft) will be aluminum most of the time. I still have not sat back and tried to figure out which trucks get whatever shaft, maybe when I get back to line I'll try and figure it out.
I have about 800 miles on the truck. So far she is smooth as glass. I am very particular, so I would notice if it werent.
I had an 02 250 scab, lb. It had a 1 piece shaft in it. I dont know when ford decides to use a 2 piece shaft. Since I have the longest 150 they make, it seems that they dont use a 2 piece in a 150. Unless they would use it in the 2wd version of the 150 inch wb since the DS would be longer with out the transfer case.
The longest F150 is the 163" Scab 8' box, with the HD payload package. Not sure if they have a 2 piece or a 1 piece driveshaft.
i had a custom steel driveshaft made for my '04 F-150 Crew Cab FX4 (60K miles) to replace the non-serviceable steel OEM driveshaft. Cost? About 400 dollars. I did have an option to go with an aluminum driveshaft for about 600 dollars. I went with a custom shaft for 2 reasons. One, i had worn u-joints. Two, because of my lift kit, my OEM driveshaft was 1 inch too short.
In my opinion, i thinks fords decision to go aluminum is to fix several problems with the old shaft.
1) vibration problems. From day one, Ford has replaced contless driveshafts.
2) non-serviceable. if a u-joint becomes worn and sloppy, like in my case, you have to replace the whole driveshaft. I am assuming the new aluminum "shaft" is servicable.
3) With aluminum, you can go to larger diameter "shaft" and still be less weight than steel. With less weight (less rotating mass) the drivetrain can accelerate quicker with less horsepower. Thus, better performance and better MPG. (I'd like to see the hard numbers on this.)
4) the larger diameter shaft can handle more torque.
not true about the aluminum drive , I have an '01 f150 supercab sb with aluminum driveshaft & i can't get rid of the vibration that i have w/aluminum drive shaft.it's been replaced ,new u-joints installed,new shocks & new rear tires.this must be one of those ford (fix or repair daily ) problems with these ford trucks(f150's). my vibration is at around 60- 65mph +
the shaft is not aluminum it is infact Stainless Steel 6061-T6 the VP part number lists it as a full stainless steel driveshaft. magnets won't stick to SS so the magnet test is useless here.
