fuel injector compatibility question
Old Aug 11, 2009 | 02:50 AM
Dustin460's Avatar
Dustin460
Can i take the injectors out of a 1990 f250, and put them into my 1996 f250?
Old Aug 11, 2009 | 06:08 AM
DBGrif91's Avatar
DBGrif91
The best answer I can give you is to pull an injector from each and compare them. If everything looks good, hook up the 90 injector to your 96 harness WITHOUT inserting it into the manifold and see if it works. If so, then I'd say yes.
It might help if you have a pair of calipers to check measurements.
Old Aug 11, 2009 | 06:14 AM
TexasGuy001's Avatar
TexasGuy001
It most likely will work. What engine is in each. If both are 302-351 or both are 300 etc then it should. I have Ford Racing injectors for a 87-93 Mustang 5.0 in my truck. As long as they are the same color they should work. There is a possibility that the connector is different, but I don't think it is. I wouldn't think the injectors in a truck thats that many years older would be better than the ones in the 96 though.
Old Aug 11, 2009 | 08:15 AM
Conanski's Avatar
Conanski
As long as they are the same color(= same capacity) they will plug in and work fine.
Old Aug 11, 2009 | 12:54 PM
Dustin460's Avatar
Dustin460
they both have 460's, im gonna just go try it, ill let you guys no how it turns out
Old Aug 11, 2009 | 03:54 PM
Dustin460's Avatar
Dustin460
Difference in the cone shape on the spray end.
The 90 has long conical cones and the 96 has a rounded end.
There is a difference in length of 1/8"
Does anyone see a problem.
PS. the reason for the swap is the injectors in 96 have 250 thousand miles and the injectors in the 90 have less than 20 thousand
Old Aug 11, 2009 | 04:06 PM
DBGrif91's Avatar
DBGrif91
I doubt you'd have to worry about it- as long as the replacement injector seals properly into the manifold and is compatible with your current system, you should be okay.
Just out of curiosity, which one is longer?
DBGrif91's Avatar
DBGrif91
Old Aug 11, 2009 | 04:13 PM
Dustin460's Avatar
Dustin460
the longer one is the 90, an the difference in length comes from the nozzle end, the length from seal to seal is the same the nozzle on the 90 ingectors are cones and 1/8in longer than the round and flat nozzle on the 96
Old Aug 11, 2009 | 05:48 PM
EPNCSU2006's Avatar
EPNCSU2006
The newer injectors probably have an updated (better) spray pattern than the older ones, but as long as the flow rates are the same, it shouldn't cause any major problems.
Old Aug 11, 2009 | 05:59 PM
Conanski's Avatar
Conanski
The overal length doesn't matter either, I have a set of Design 3 injectors here and they fit these trucks no problem as long as you use at least 4 of the same on each side of the engine.. and preferrably a complete set of 8.
Old Aug 11, 2009 | 06:02 PM
Dustin460's Avatar
Dustin460
so i got them in and crank crank crank no start, and im sitting there like dam there not gonna work, then i get out and plug the ignition coil back in lol (i had forgot that minor detail) and she fired right up
thanks to everyone who gave me an answer on this
cory5517
Oct 24, 2013 07:19 AM
f1501987
Apr 28, 2012 06:05 AM
skidrow01
Modular V8 (4.6L, 5.4L)
Feb 29, 2008 04:14 PM
88f250hd
Sep 7, 2005 11:23 AM
