351 injector specs
Old Sep 3, 2005 | 12:02 AM
88f250hd's Avatar
88f250hd
Post 351 injector specs
does anyone know what the specs are for the injectors in a 88 F-250 with a 5.8L (351w). I want to upgrade to larger injectors. Thanks...Blaine
Old Sep 3, 2005 | 01:59 AM
pfogle's Avatar
pfogle
Should be 19lbs/hr. What color are they?
Old Sep 3, 2005 | 02:21 AM
Matt95L's Avatar
Matt95L
If you don't even know what size they are why do you think you need to upgrade?The stock 19s(Orange) took my truck a long ways.
Old Sep 3, 2005 | 10:27 AM
TigerDan's Avatar
TigerDan
Not much point to stepping up a size unless you do other mods as well. Just sticking larger injectors in isn't going to give you a big boost in power.
Old Sep 3, 2005 | 07:20 PM
88f250hd's Avatar
88f250hd
my 5.8 is a 1985, bored .030 over, has crane cam with .456/.484 lift, 260/272 duration, the heads have been ported, gasket matched, valves are same size as 1969 specs, have flowtech shorty headers, and true dual exhaust. I would like to put an aftermarket throttle body on it, so I was trying to figure out how much bigger I needed to go with the injectors to match up with the throttle body...Blaine
Old Sep 3, 2005 | 09:57 PM
TigerDan's Avatar
TigerDan
Okay Blaine, that tells us a bit more. Have you done a mass air conversion on it? The mods you've done so far shouldn't make the Speed Density too unhappy, but if you go to a bigger throttle body and larger injectors, it might have a wee bit of trouble trying to figure out what's going on.
But, as to our original question, I think pfogle and Matt95L are right about the stock injectors being 19lbs/hr.
Old Sep 4, 2005 | 03:11 PM
SVTCobra306's Avatar
SVTCobra306
Yes, stockers are 19 lbs/hr. Typically good for about 300 horsepower.
Old Sep 5, 2005 | 02:24 PM
Jimbo302's Avatar
Jimbo302
19lb's should be more than adequate for that.
Old Sep 7, 2005 | 12:06 AM
88f250hd's Avatar
88f250hd
nope, no mass air. does run pretty strong now. will probably leave it as is. thanks for all the replies....Blaine
Old Sep 7, 2005 | 11:23 AM
Kemicalburns's Avatar
Kemicalburns
well even if you wanted to go bigger injectors the computer couldnt handle it. if you upgrade to a larger throttle body it wont do much good unless you get a different intake as well.
brcwelding
Oct 2, 2012 02:05 AM
Frozen_Joker
Jun 25, 2011 08:14 AM
zanthius
Jun 13, 2005 09:02 PM
schapman
Nov 13, 2003 10:29 PM
schapman
Nov 12, 2003 12:25 AM
