Another door lock question
Old Aug 10, 2009 | 01:00 AM
natew's Avatar
natew
All 5 of my power door locks do not work. Well they try to work by making sound and the door lock wiggles a bit. I dont have a owner's manual so I do not know where to look to check the relay. Also I understand that it may be a ground. Where do I look to check the ground? I will lastly check the actuators, but all 5 not working???? I bought the X with all 5 not working, but maybe they went one at a time???? Any help would be great.
Thanks
Old Aug 10, 2009 | 02:02 AM
EXv10's Avatar
EXv10
If it's a 2000 with that many miles and they all wiggle a little I would say all 5 are bad. Luckily if you have a little mechanical inclination you can fix all 5 of them for free. (or pay about $800+ to have it done.) I just used tin foil to replace the thermisters instead of wrapping them. Do a search and you will find how to fix them. Mine even open/close with a clunk now so I know they lock/unlock from a distance with my FOB.
Old Aug 10, 2009 | 09:01 AM
cbradford's Avatar
cbradford
Here is a link to the Excursion Tech folder for the fix for your actuators:
https://www.ford-trucks.com/forums/5...ch-folder.html
Old Aug 10, 2009 | 11:59 PM
ptolalibertad's Avatar
ptolalibertad
i just bought all new actuators...the first one you replace is hard..then it gets easier and faster to do....bought them from a FTE sponsor
Old Aug 11, 2009 | 01:20 AM
EXv10's Avatar
EXv10
I left some things intact on my doors like the black cable and didn't remove any door handles. I used a little flashlight and and little mirror too. Those little mirrors are kind of hard to find but I always keep one in a sandwich bag in my toolbox. Long skinny screwdrivers help in there also. The less you remove the faster it will go. Just don't break anything.
jenkinsj
Electrical Systems/Wiring
Mar 10, 2013 08:14 PM
sandaholics
Oct 26, 2011 09:22 AM
kmbet
Jun 3, 2008 01:44 PM
