Troubleshooting a No-Start condition
Old Jul 3, 2012 | 03:32 PM
bismic's Avatar
bismic
EDIT - if you decide on the ScangaugeII instead of a phone app ......................... See below. BUT - remember the ScanGauge is a POOOR code reader!
Also, a ScangaugeII (around $150) makes it a lot easier to troubleshoot problems - especially a no-start. I will link a few good threads on this as I get time!
Here is one thread discussing hw to program the SGII:
https://www.ford-trucks.com/forums/1...l#post10227382
Also, here are some good videos on the air pressure testing:
https://www.ford-trucks.com/forums/1...l#post11979227
Old Sep 24, 2012 | 06:03 PM
creator's Avatar
creator
Originally Posted by GryphonJax
I hear the fuel pump turn on, and it cranks very well. It just doesn't seem to want to fire off. Glow plugs appear to be operating normally... (I don't have a way to test them, not tools)
Checking the engine RPM and ICP% with AutoEnginuity, ScanGauge II or any other live data scanner would be the easiest next step.
If you don't have those you can use a bluetooth adapter off ebay and your android phone with the Torque Pro app. Together the cost will be $20 and you can monitor any live data just like AutoEnginuity or Scangauge and read codes.
I use the Blue one:
Mini ELM327 Bluetooth Wireless OBDII OBD2 Auto Car Diagnostic Scanner Tool V1.5 | eBay
And make sure you use the Pro version of the Torque app since it has the formulas already installed.
Old Sep 22, 2013 | 10:45 AM
bismic's Avatar
bismic
Here is a "YouTube Index" of many helpful videos from DieselTechRon. Several on no-start troubleshooting, but also much more.
http://www.youtube.com/results?searc...Diesel+TechRon
http://vidgrids.com/powerstroke-6.0-ford
Old Oct 19, 2013 | 08:57 PM
bismic's Avatar
bismic
No Start testing with a scangaugeII
Old Jun 14, 2014 | 08:57 PM
bismic's Avatar
bismic
Another troubleshooting resource:
http://oregonfuelinjection.com/pdf/f...diagnostic.pdf
Old Mar 4, 2017 | 07:12 PM
bismic's Avatar
bismic
Troubleshooting SYNC and FICM SYNC problems
SYNC is achieved when the PCM receives a signal from the Crankshaft sensor (CKP) indicating the sensor is working and the correct signal has been identified by the PCM. If the Crankshaft sensor is working improperly, the PCM cannot calculate engine speed or cylinder position, preventing fuel delivery.
Diagnosing SYNC:
Using the WDS, select the SYNC PID. This PID will be viewed as a YES or NO on the top of the data screen. KOER, SYNC should always read YES.
SYNC is totally derived from the CKP sensor. It is possible to have no CMP sensor signal and still have SYNC (YES) and an RPM signal.
NO SYNC and no RPM signal, typically is a faulty CKP sensor/circuit problem.
FICM SYNC
"The FICM uses CMPO (Camshaft Position Sensor Output) and CKPO Crankshaft Position Sensor Output) signals, which are sent by the PCM, to calculate FICM SYNC. FICM SYNC is calculated by the FICM and is the correlation between the camshaft pin and the crankshaft triggers. Once FICM SYNC is achieved, the FICM uses engine speed, MFDES (Mass Fuel Desired), EOT, and ICP to calculate fuel timing, pulse width, and pilot injection usage. If the CMPO and CKPO signals are not properly timed,
FICM Sync may not occur."
Diagnosing FICM SYNC:
Note: Always diagnose any SYNC issues before diagnosing FICM SYNC issues.
Using the WDS, select the FICM SYNC PID. This PID will be viewed as a YES or NO on the top of the data screen. KOER, FICM SYNC should always read YES.
If there is no FICM SYNC while cranking the engine, then the problem is limited to the circuit illustrated below. The FICM SYNC circuit relays information from the PCM to the FICM.
Engine Wiring Harness: FICM SYNC occurs through two circuits between the FICM and PCM. Verify engine wiring harness circuits CMPO and CKPO. If one of these two circuits has a short/open, FICM SYNC will not occur.
PCM: If the PCM is not working properly, FICM SYNC may not occur.
FICM: If the FICM is not working properly, FICM SYNC may not occur.
CMP If the CMP signal is corrupt (electrical or mechanical), FICM SYNC may not occur.
If you have cam/crank sync, but no FICM sync, then the main culprits are:
- FICM - usually indication of a logic side problem
- Camshaft sensor (CMP)
- PCM
FICM SYNC- FICM SYNC is calculated by the FICM and is the correlation between the camshaft pin and the crankshaft triggers.
SYNC- SYNC is achieved when the PCM receives a signal from the crankshaft sensor and camshaft sensor indicating they are working and in time.
"If there is no FICM logic power to the FICM, the injectors will still buzz once the key is cycled but the engine will not start. There will be no other
symptoms related to the no start condition."
The FIVE FICM ground pins (1, 2, 3, 22, 26) are all tied together inside the FICM. Hence, no independent affect on a PID.
"The net time between pulses is equivalent to the fuel pulse width (FuelPW) used to provide fueling.
The coil on time is currently calibrated from “400us to 5.8ms”. The 5.8ms is for cold starts. As the engine warms up the duration decreases and settles around 800us depending on the amount of fuel being commanded."
Old Mar 4, 2017 | 07:19 PM
bismic's Avatar
bismic
Due to some broken links, I will try to attach some documents
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Mar 4, 2017 | 07:40 PM
bismic's Avatar
bismic
A couple more attachments
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old May 29, 2017 | 10:05 PM
BLADE35's Avatar
BLADE35
Originally Posted by BLADE35
If you want to verify those circuits, you can connect a DVOM to both the CKP and CMP circuits of the middle PCM connector.
Set your DVOM to Hz. On the CKP circuit, you should be seeing 150 to 200 Hz when the engine is cranked over (directly proportional to 150 to 200 RPMs).
On the CMP circuit you should get a reading of 1.1 to 1.9 Hz when the engine is cranked over. Hopefully you won't have to go this far before you resolve your issue.
__________________
The spec is between 300 to 400O for the CKP sensor, and 800 to 1100O for the CMP sensor. If you want to check readings, set your DVOM to read Hz.
The CKP reading you should be getting from the CKP sensor, is between 150 to 200Hz, directly proportional to engine cranking RPM when the engine is cranked over.
The CMP reading should be between 1.1 to 1.9Hz when the engine is cranked over.
This was a copy and past from mchane posts
Old Mar 27, 2018 | 01:58 PM
bismic's Avatar
bismic
Wanted to document this tip in the no-start thread.
Method to close the IPR from jumpering pin #2 of PCM connector C1381c (the middle of the three PCM connectors between the driver side battery and the inner driver side fender well which requires the battery cover removed to access unless it's MIA), to ground. It is the yellow wire with red stripe. This is the ground side wire to (switched) the IPR. Since it is a switched ground and switched power to the IPR, the key needs to be in the run position (KOEO).
https://www.ford-trucks.com/g/album/9417562
Note - On the IPR connector, Pin 1 is VPower (switched power) and Pin 2 is the ground from the PCM connector.
bismic
Mar 18, 2017 08:30 PM
rickwells
Jun 20, 2011 05:57 PM
GT350Mike
Jun 22, 2010 07:34 PM
AXE168
Jun 16, 2010 10:01 AM
waltinkfalls
May 28, 2005 03:29 PM
