Stripped Fuel filter cap
Old Mar 12, 2012 | 12:16 PM
dwalphinVT's Avatar
dwalphinVT
I finished doing the blue spring mod and stripped the secondary fuel filter cap in the process. I have been searching on ebay/online for another because my local dealership wants $66 for a new one. I wanted to check to make sure if i need to get a OEM part instead of an aftermarket one or one of these billet caps. Any suggestions would be great. Thanks!
Old Mar 12, 2012 | 12:57 PM
Ian123's Avatar
Ian123
I bought one off eBay for $24. How did you get the stripped cap off? I'm waiting til my next filter change to figure it out lol.
Old Mar 12, 2012 | 06:04 PM
bismic's Avatar
bismic
Ford_Doctor wrote up a procedure on it. He drilled a couple of holes in the top. Then he used a socket like those on page 158 of the pdf in the link below:
http://www.toolsunlimited.com/pdf/ToolsCat_73.pdf
They called it a locknut socket. I would call it a spanner socket.
You could also search the FDDTS web pages for his article.
Old Mar 12, 2012 | 07:08 PM
69cj's Avatar
69cj
Stick with the oem cap. May be expensive now but a lot cheaper in the long run. Try Tousley ford.
Old Mar 13, 2012 | 03:01 AM
matty169's Avatar
matty169
Address.....
P.M. me your address if you still need one.
Old Mar 15, 2012 | 08:28 PM
dwalphinVT's Avatar
dwalphinVT
Sorry for the delay but thank you for the responses. I have looked on ebay and those prices are a lot easier on the eye but i was thinking I would have to go with an OEM versus aftermarket like you need to with the oil filter cap. Thanks for the instructions for getting the cap off, like an idiot I used a 12pt socket instead of a 6pt but will wait until next filter change to try to get it off.
Old Mar 15, 2012 | 10:04 PM
powerstroker100's Avatar
powerstroker100
This happened to me on my first 6.0 (an 04) and I tapped the cap off with a chisel and hammer, drilling method is probably better and faster
Old Mar 15, 2012 | 10:23 PM
bismic's Avatar
bismic
Here is the link to the article I was referring to:
DTS Articles - Broken 6.0L Secondary Filter Caps
Old Mar 15, 2012 | 11:09 PM
Ian123's Avatar
Ian123
I'm afraid that I would damage the housing, or drill into the standpipe. Plus I don't have a spanner socket. I think what I'm going to do is super glue a socket onto it and hope it will get enough of a grip.
Old Mar 16, 2012 | 07:10 AM
critterf1's Avatar
critterf1
Why not use a 1/2 drive ratchet in the center of the cap?
Old Mar 16, 2012 | 07:14 AM
npccpartsman's Avatar
npccpartsman
Because that square drive breaks very easily also
Old Mar 16, 2012 | 07:17 AM
critterf1's Avatar
critterf1
If you have to replace it anyway why not give it a shot?
Old Mar 16, 2012 | 11:49 AM
Ian123's Avatar
Ian123
I tried that after I stripped it and it broke in half
Old Mar 24, 2012 | 10:54 PM
SwanyRiver420's Avatar
SwanyRiver420
Tried everything........
Stripped it, broke it with the socket, screwdrivered it, chiseled it.
Now with just really the threaded part in the housing, what would you recommend? It never budged and I am almost sure at 130K someone(Ford) has never seen the inside of this filer housing.
What to do now?
Old Mar 24, 2012 | 11:01 PM
bismic's Avatar
bismic
You can always buy a new filter base (oil and fuel filter unit).
