97 Explorer 4WD upper ball joint
Old 08-05-2009, 04:33 PM
pete315's Avatar
pete315
pete315 is offline
I need to change both left and right upper ball joints on my truck. they both look original. left side is a 1 piece, right side is a 2 piece. question- why did they only put a 2 piece on right side? appears it would be so much easier to replace the right side joint w/o having to remove the control arm. is there a problem if I replace right side with a Moog 1 piece controlarm/ball joint? will I still be able to get all the proper alignment adjustments when I get truck aligned? or should I replace the right side with the 2 piece unit. If I replace the right side with the 2 piece unit, I assuming the cntrol arm does not have to be removed?
Old 08-06-2009, 08:48 AM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
OEM was a one pc, so the 2pc side has already been replaced at some time in the past.
Replace both sides with the 2 pc parts, alignment will need to be done.
TeamExploder's Avatar
TeamExploder
TeamExploder is offline
Replace the ball joints with the either 1 or 2 piece, I haven't noticed a difference in quality
Old 08-06-2009, 08:52 AM
aquanaut20's Avatar
aquanaut20
LOL, TeamExp, we have differing opinion, except for the Moog.
I would also replace the lower BJ, they usually fail before the uppers.
Old 08-06-2009, 09:05 AM
pete315's Avatar
pete315
pete315 is offline
the lowers were changed by the previous owner by a Ford dealership about 30,000 miles ago. they have no play and the boots are still in good shape. I really don't have play in the top right side ball joint but the boot is ripped and I can see and feel that that there is no grease in there.
Old 08-06-2009, 09:08 AM
pete315's Avatar
pete315
pete315 is offline
would you recommend the 1 piece?
Old 08-06-2009, 03:04 PM
aquanaut20's Avatar
aquanaut20
Yes, but since I keep my rides for a long time I find the 2 pc to be more convenient, the bushing don't need to be changed out as often as the Bj's.
I do a lot of off-road driving with heavy dive gear in the truck and a 10# winch up front.
Old 08-06-2009, 10:38 PM
pete315's Avatar
pete315
pete315 is offline
just curious, why do you feel the 1 piece is better?
mikebabyak
07-12-2015 02:01 PM
codger
1983 - 2012 Ranger & B-Series
06-16-2013 12:37 PM
m@m
2004 - 2008 F150
05-14-2012 09:34 AM
pete315
08-12-2009 12:19 PM
Quick Reply: 97 Explorer 4WD upper ball joint
