Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- How To Replace Upper Control Arm
Step by step instructions for do-it-yourself repairs
Upper Control Arm Question
I have a 1999 Explorer with 2wd. I am going to replace all the ball joints. The upper passenger side is currently a 2 piece design. Moog makes a 1 piece control arm to replace it. Am I able to use the 1 piece arm to replace the 2 piece upper control arm which is on it now? The 1 piece replacement will have the bushings installed included. The 2 piece control arm with ball joint does not have the bushings.
Even Ford updated the OEM part, and uses the updated one piece design.
Bushings are pre installed and 2 camber kits are usually needed for proper alignment.
The matching drivers side upper control arm is Moog K8708T. Check Amazon pricing.
http://www.moogproblemsolver.com/_pd...K10_106_En.pdf
Purpose of 2-piece U.C.A.
The 2-piece upper control arm's purpose is to allow MATCHING, i.e., fine-tuning, of caster angle wheel-to-wheel.
The caster must be as nearly identical, regardless of it's actual amount, on both front wheels, to ensure the best possible straight-tracking of the vehicle.
The literature calls the slight caster difference between wheels "Caster-Split".
impish
impish
But surprisingly Amazon is actually a lot cheaper for these arms, good tip.
AKSTAR
Aerostar
15
05-27-2006 06:11 PM
twallace
09-15-2004 03:10 PM
