Front Axle
Old Aug 3, 2009 | 01:50 PM
jle70's Avatar
jle70
Front Axle
Three questions:
1. How to tell which axle I have to get rotors for?
NAPA:
Brake Rotor Only - Front - Premium
w/ 3,800 lb. Axle NB 4885731 $45.99
Over 8,500 lb. GVW NB 4886476 $45.99
4600 Pound Drive Axle NB 4886789 $53.49
2. Anyone know the correct "hub tool" I need?
3. Other items needed, correct numbers?
BK 6005155 Flex Plate 1 $82.49
RR 94153 Shock - NAPA Response - Front 2 $29.99
Old Aug 3, 2009 | 02:04 PM
Neal 97 250's Avatar
Neal 97 250
They only put one axle in these 250's. It is a dana 50 TTB.
The truck has a GVWR of 8800 (mine does anyway) So you need the ones for over 8500 lbs. (the middle ones listed above.)
Brown Falcon's Avatar
Brown Falcon
Should be a axle rating on the drivers side door sticker. Not sure the exact hub tool you need. I'm sure someone else will chime in shortly.
Old Aug 3, 2009 | 02:17 PM
jle70's Avatar
jle70
Thanks. I'm kind of worried about taking this apart, never had 3/4T apart. Have had 1/2T apart alot.
Old Aug 3, 2009 | 02:22 PM
Brown Falcon
Shouldn't be too different than a 1/2 ton. It's been a few years since I had a 4wd apart though...
Old Aug 3, 2009 | 02:24 PM
jle70's Avatar
jle70
Would it be a good idea to replace front axle u-joints at this time?
Old Aug 3, 2009 | 02:32 PM
Brown Falcon
If it hasn't been driven hard or had the 4x4 used a lot I wouldn't worry about the front joints much. If you offroad it a lot I would replace them.
OT, I think that someone should donate a Dana 60, front leaf springs, and the 4x4 steering parts to me... Just a thought...
Old Aug 3, 2009 | 09:30 PM
joe_13894's Avatar
joe_13894
Unless they're closer to the left coast and then they could send it my way instead.
Ex Factor
Mar 29, 2011 07:06 AM
mich800
Nov 5, 2010 10:24 AM
pgw85706
1983 - 2012 Ranger & B-Series
May 16, 2007 03:45 AM
stirfrysteve
Apr 27, 2005 07:54 PM
nb1997
Jan 30, 2005 09:08 PM
