Engine options
Old Aug 5, 2009 | 06:24 PM
tjbeggs's Avatar
tjbeggs
Turbo is the same on the OBS van but the SD (99-03) vans they are different. Oil cooler might be different. Other than you should be good to go.
Old Aug 5, 2009 | 06:27 PM
WALJON's Avatar
WALJON
You will not need to buy a down pipe Dirk vans have the normal round down pipe I can see it in your pic there there.
Old Aug 5, 2009 | 06:35 PM
tjbeggs's Avatar
tjbeggs
I don't think the van DP will fir a pickup though
Old Aug 5, 2009 | 07:17 PM
WALJON's Avatar
WALJON
That's too bad could have saved some cash
Old Aug 5, 2009 | 11:02 PM
Diesel_Dirk's Avatar
Diesel_Dirk
Started stripping the new engine of its unwanted components tonight.
Oil cooler is different. To be exact the end with the filter mount is different. It points the filter straight down, whereas the truck one points it into the side of the oil pan, which concave at that point, so the filter clears the front differential. These still have to be swapped.
And I took a set of calipers to my truck downpipe ans its 3". Not sure whose pipe but its deffinitely not stock. And the rest of the exhaust is 3.5" all the way back.
No new pipe needed.
Will get the rest stripped off it tomorrow and the engine cleaned up. A little paint wouldn't hurt either.
Old Aug 6, 2009 | 12:28 AM
aaron ford's Avatar
aaron ford
You got a fairly low mileage 'Stroke for $1000USD? Wow!!! Good find!
That would buy you a rebuildable core around here. Maybe...
Aaron
Old Aug 6, 2009 | 08:40 AM
Diesel_Dirk
$1000CDN.....
Couldn't pass it up. I was considering injector(s) replacement, but at that price....
Old Aug 6, 2009 | 10:16 AM
Brown Falcon's Avatar
Brown Falcon
Originally Posted by Diesel_Dirk
$1000CDN.....
Wow! That's awesome!
73fan
Jan 4, 2013 12:55 PM
OverHeight
Jun 22, 2011 07:19 PM
patrickgw
1983 - 2012 Ranger & B-Series
Mar 11, 2004 10:51 AM
emtabmm
Dec 4, 2003 05:04 PM
