I have an 03 6.0L. 240,000 km. New Turbo & EGR delete 10,000km ago. New injectors 2,000 km ago. Still gutless. Idling warm engine load is at 26%. Cruising empty, 50-60% load. TERRIBLE on fuel! ICP @ idle warm: 637 psi. IPR Duty 24%. ICP with load: 3,500 IPR duty 75%. Don't know what to do anymore!
FICM runs at 47.5 to 48.5 consistent. EBP line is clear, removed sensor and had exhaust coming through. (Is straight piped as well) MAP sensor reads 13 psi or so and increases as boost psi increases. IAT is fine. MAF seems ok as well.
IPR screen; don't know. Wouldn't the duty cycle be higher then, to try to keep pressure up? ICP & ICP desired remain within several psi. Fuel pressure I did try to check with a gauge that goes to 60 psi. It hit the stop on the other side of the "0" the moment I turned key on!
630 is high? I was also told too low! Should be 800-900. Suspected HPO system leak.
IPR screen I was thinking just check it to rule it out. Fuel pressure you need to watch under load, have you done the blue spring upgrade? Do you run a tuner? If your truck has always run 630psi ICP at hot idle then I would think its ok. I am with you and don't think its a HPO system leak.The 2003 HPO system is a little different then the 2005. Have you ever had the FICM repaired/replace? If not then I would rule everything else out and try that.
Might check that IPR. And fuel pressure under load. Bout the blue spring upgrade, don't know as I just got the truck recently. I do have edge evolution for it, but from stock to extreme makes very small difference in power. Does the HPO run higher on 2003 than on later years?
The FICM does look very new, among the newest things under the hood, so I think it's been replaced.
OPERATING VALUES
Just make shure the numbers are taken exactly like this
Truck in PARK OR NEUTRAL all times during test
ECT at 190* or close to And EOT at 185* or higher
A/C OFF
#1-------KOEO=Key On Engine Off =record EACH sensor value and POST IT!!
#2-------Low Idel (truck idel on its own)=record EACH sensor value and POST IT!!
#3-------High Idel (2500RPM)=record EACH sensor value and POST IT!!
I know you posted some of these sensors values But they must be taken Exact
So looking for 3 Values per each sensor here Post them for these
ICP
ICPV
IPR%
BARO
MAP
EBP (03 uses Inferred EBP so you might not get a Value for this one)
MAFV
Volt
FICM MP
