Sponsored by: Auxito
clock spring?
Old Aug 3, 2009 | 04:26 AM
2020's Avatar
2020
clock spring?
I just bought a 97 f 150 and the cruise and horn doesn't work.Is this just the clock spring and how do I check?
Old Aug 3, 2009 | 05:58 AM
torkum's Avatar
torkum
First I would pull the cover off the steering column and check the wiring. Check the fuses too.
Old Aug 3, 2009 | 01:46 PM
1Aauto's Avatar
1Aauto
Former Vendor
It's more than likely the clock spring.Those are symptoms that there may be a broken wire on it.The airbag light may illuminate too. If you decide to poke around in there disconnect the battery before you do it.
Old Aug 4, 2009 | 04:24 AM
2020's Avatar
2020
Fuses are all good.Should I get a code?
Old Aug 4, 2009 | 06:10 AM
torkum's Avatar
torkum
You will have a airbag fault code if the airbag light is on. Have you pulled the cover and checked the wiring?
Old Aug 4, 2009 | 08:40 PM
2020's Avatar
2020
You mean the cover around the steering column?If so,I'll check that.
Old Aug 4, 2009 | 09:27 PM
torkum's Avatar
torkum
That's the one. Follow the multifunction switch wires and the horn wires.
Old Aug 6, 2009 | 08:05 AM
fivestarairbags's Avatar
fivestarairbags
Turn the key on and the airbag light will illuminate for 6 seconds. It will then go out and come back on and probably flash 3 times and then pause and flash 2 times. It will repeat this code several times before staying illuminated constantly. This would be a code 32 which is a driver airbag code. This code almost always points to a defective clockspring which will also keep the cruise and horn from working. Once replaced (and it's fairly simple to do) the light will clear by itself. Nothing will have to be cleared by the dealer or scan tool.
evoroadster
Sep 12, 2016 06:22 PM
gbrown31
Feb 18, 2014 01:17 AM
garydmundy
Dec 17, 2012 05:59 PM
Quackhead94ranger
1983 - 2012 Ranger & B-Series
May 25, 2004 09:20 PM
jrobison
Nov 9, 2003 09:24 PM
