front wheel seals
Old Aug 2, 2009 | 11:19 AM
Davey F150's Avatar
Davey F150
front wheel seals
I replaced the rotors on my truck and regreased the wheel bearings ect. Why are the seals two piece set. What is the first one for that slides over the spindle. A dust cover? The problem is they squeel . If i spray a little lube on them it stops . its anoying. Im thinking of removing the one that slips over the spindle and just having the one pressed into hub. Anyone have this problem. I did grease them when i put it all back together but once the grease pushes away it starts sqeeling.
1996 f150 5.8 4x4 man hubs.
Thanks Dave
Also anyone have the overdrive light on th gear slector flash. what does this mean?
Old Aug 2, 2009 | 11:33 AM
Sycostang67's Avatar
Sycostang67
Did you put a little grease on the seal lip when you installed them?
I think the flashing light means you have a transmission problem. You'll need to pull the code to find out exactly what it is.
Old Aug 3, 2009 | 03:45 PM
Davey F150's Avatar
Davey F150
yes i greased them anyone have any of these problems
Old Aug 3, 2009 | 10:51 PM
HrdDrv's Avatar
HrdDrv
Isn't that a wear sleeve for the spindle? They're only used when the seal surface on the spindle is worn bad.
Old Aug 3, 2009 | 11:05 PM
andym's Avatar
andym
I've never seen a two piece seal on these before. Normally there is just one seal that is set into the back of the rotor.
Old Aug 4, 2009 | 03:38 PM
Davey F150's Avatar
Davey F150
Yes . There is another piece that slides on to the spindle first. It was also this way when i removed it.
Old Aug 4, 2009 | 03:41 PM
Davey F150's Avatar
Davey F150
Dan there is only normal wear. im not sure what it is for. they were there from the factory. i have owned it since new and this is the first tme they were removed.
sarnott140
Mar 30, 2012 10:15 PM
cline9394
22
Dec 10, 2009 08:17 AM
buck_
19
Sep 23, 2006 09:13 PM
jman92612
Dec 19, 2004 11:56 AM
Josh79
Oil & Lubrication
Nov 23, 2004 01:14 PM
