Sponsored by: Real Truck
Can't get hub back on.....please help
Old Mar 29, 2012 | 09:28 PM
sarnott140's Avatar
sarnott140
I just finished changing my hub seal on my driver side rear wheel. Now I cant get the hub back on, the seal just wont slide over the spindle, tryed pounding it with a 4lbs hammer, pushing with my foot, but it just wont go. Anyone else have this problem. Also the spindle is grooved where the old seal was
Old Mar 30, 2012 | 09:29 PM
05SuperPooper's Avatar
05SuperPooper
There is a tool to drive those seals in without destroying them. Search out the ball joint replacement threads and you will see the necessary steps to R and I those seals.
Old Mar 30, 2012 | 10:01 PM
05SuperPooper
I think I used a three or four inch PVC coupling and a block of wood to carefully install mine
Old Mar 30, 2012 | 10:15 PM
CampSpringsJohn's Avatar
CampSpringsJohn
You install the seal in the hub. 05Super is correct in that you can use a block of wood to get the seal in the hub. However, you may have the wrong seal. There are 2 wheel seal diameters for the spindles that have the 2.250" inner wheel bearing. The seal surface is one of 2 possibilities. 2.875" and 2.955" If your truck is an F350, you MIGHT have an inner bearing of 2.500". If that's the case, you need a wheel seal with a 3.250" diameter where it goes on the spindle. If you're trying to slip the seal on the spindle to see if it's the right one, with a little oil, it should go on with little effort. And, be sure to put oil in the hub before you slide the outer bearing on the spindle.
bill davis
Large Truck
Oct 8, 2010 04:16 PM
Paul Dozoretz
Dec 28, 2008 07:19 AM
DR JOE
Feb 27, 2008 10:28 PM
CBFryman
1983 - 2012 Ranger & B-Series
Aug 16, 2006 04:32 PM
someday
Jan 19, 2006 08:38 PM
