Sponsored by: Auxito
Instrument Cluster Exchange Question
Old Aug 1, 2009 | 07:43 PM
musickerns's Avatar
musickerns
I have a 2001 Ford F150 7700 payload truck and to my surprise there is no tachometer in the instrument cluster. I rely upon the tachometer to check various things such as the transmission slipping or other automotive problems. My question is this:
Is it possible to exchange the instrument cluster in a 2001 F150 for one that has a tachometer included in the cluster? Is the truck pre-wired for this option?
I would like to get an instrument cluster with a tachometer included from the salvage yard and install it verses purchasing an after market tachometer that has to be bolted somewhere on the dash.
Old Aug 2, 2009 | 06:23 AM
projectSHO89's Avatar
projectSHO89
If your truck is equipped with PATS, any cluster exchange will have to be performed by a dealer because the PATS system incorporates the cluster. The dealer tech would have to reprogram the replacement cluster so it would operate properly with the rest of the system.
FWIW, it would probably be cheaper to install a ScanGauge II since RPM data is sent to the cluster by the PCM.
You can also put your cluster into HEC Dealer Test Mode and display the tach data on the digital odometer.
Old Dec 18, 2009 | 02:36 PM
1975IH200's Avatar
1975IH200
I used the search function and this was the only one that was similar to my question.
I have an almost identical question.
My truck is a '98 F-150 XL 4x4, Has speedo & mechanical odometer and it does not have the tach. Also no PATS, no PW, no PDL, no remote entry etc.
Can I install an instrument cluster from an '98 XLT with tachometer from a salvage yard and have it all work OK?
Also, how would I change the odometer to read the correct mileage?
Thanks.
Building_Fords
Feb 19, 2017 06:58 PM
billh1963
WTB - Parts & other
Sep 17, 2015 08:52 AM
aurgathor
1978 - 1996 Big Bronco
Mar 30, 2015 05:07 PM
iwantanf150
2004 - 2008 F150
Aug 12, 2007 06:38 PM
GST97
Sep 19, 2004 12:45 AM
