OEM tachometer wiring?
Old Sep 18, 2004 | 11:16 PM
GST97's Avatar
GST97
I have a 92 F150 5.8L.
I have the OEM tach in the instrument cluster, however when I turn the key to the on position, the tach goes to 500 RPM. When I start the truck, it goes to around 2000RPM and just stays there no matter what RPM The truck is at.
My question, is where does it get this tach reference from?
In diagrams I see a tach signal coming off the ignition coil? Is this the wire it gets its info from?
If so, how do I test to make sure that the tach signal is correct or if it is the gauge that is faulty? My manual does not have any information that I can find about diagnosing tachometer problems.
Thanks,
-Chris
Old Sep 19, 2004 | 12:45 AM
EPNCSU2006's Avatar
EPNCSU2006
If your truck is running, then the signal should be correct. The ground on the coil is switched every time a cylinder fires, so the tachometer just keeps track of the frequency that the circuit is grounded and converts that to a revolutions per minute reading. I'm not really sure what, if anything, is between the negative side of the coil and the tach input wire on the instrument cluster.
carsronnie86
May 24, 2016 04:22 PM
southtexasidi
Sep 29, 2015 07:43 PM
uh60
Nov 17, 2013 07:23 AM
Zebich
Feb 20, 2005 10:20 PM
