No Crank No start
When you turn the key have someone listen to see if you hear the starter solenoid click and starter motor kick... If so, then Bluegrass is right......... loss of oil pressure is not good.......... try to turn the motor over with a breaker bar on the crank pulley, or big screwdiver - prybar on the flywheel teeth.
It certainly doesn't sound good & Bluegrass7 and Steve(ill) make very good & valid points.
Another quick check to try is to slip the serpentine belt off and try to start it...if it starts or at least turns over pretty normally, then you know something on the belt drive is the issue & causing the locked up
JACKA$$
19
04-25-2010 03:54 PM
