Hand Cranking
Old May 19, 2011 | 06:32 PM
poocher pup's Avatar
poocher pup
Hand Cranking
ok the truck has sat for 6 months now because of surguries and wanted to ask if anyone thought it would be better to turn motor over by hand a few times to get oil to heads? this is truck in my sig. thanks for any answers.
Old May 19, 2011 | 08:22 PM
farmert's Avatar
farmert
I would just use the starter. Chances are that the fuel has leaked down and you will have to crank for a few seconds, and by the time it starts the oil pressure will have built up.
Old May 19, 2011 | 08:35 PM
farmert's Avatar
farmert
By the way, Hows the leg? Are you good as new yet? I hope so.
Old May 19, 2011 | 08:37 PM
poocher pup
thanks, just thought that getting oil to valvetrain would be more like on a rebuild.
Old May 19, 2011 | 08:45 PM
poocher pup
i'm up walking without any support but not 100%, about 75% i'd say. harder to relearn to walk than to learn the first time. It's a pricey thing($7500) and it's not el/macanical at all, but has rotation and built in shock absorber to make walking easier.
Old May 19, 2011 | 09:50 PM
Marianna2003's Avatar
Marianna2003
Just disconnect the fuel IP solenoid and crank until you see oil pressure. Reconnect IP solenoid and you should be good to go.
Old May 20, 2011 | 12:03 AM
Country_boy_2007's Avatar
Country_boy_2007
if your gunna crank it you might as well try to get it to start, just watch the oil pressure if it fires up, you wont move much oil cranking it by hand
skipper32
Jan 26, 2012 05:22 PM
Leemakesmepee
25
Dec 20, 2011 10:39 AM
FuelInjected1
42
Oct 23, 2009 01:52 PM
BAD351W
Offroad & 4x4
May 6, 2009 05:20 AM
christop43
25
Mar 11, 2003 01:06 PM
