Need some Switch ID help
Old Jul 30, 2009 | 05:24 PM
Wyatt66f100's Avatar
Wyatt66f100
hey guys ive been trying to figure out for a while what this is that i have here. when i bought my new 66 cab for my truck it came with a mount to mount what i think is a turn switch. it mounts just under the bottom lip of the dash in the middle. i have the mount for the switch and i think i have the switch somewhere... i just dont remember taking it out. anyways the mount for the switch has four options "off" "on" "Emer" and "flasher" what is this thing? i already have a flasher switch in the dash. in one of the six holes
Old Jul 30, 2009 | 05:30 PM
camperspecial65's Avatar
camperspecial65
If its a flat plate painted black and has 2 holes...thats the mounting bracket for the heat and temp cables used on trucks with the deluxe heater option.
The 4 way flasher switch and light is below the cluster in the metal dash itself and both the switch and seperate light bezel are right next to each other.
- cs65
Old Jul 30, 2009 | 05:48 PM
Wyatt66f100
i know thats what i dont get its got only one hole with those options on a plate like what your talking about. maybe numberdummy can help
Old Jul 31, 2009 | 07:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It's not a turn signal switch because that's bolted to the upper flange in the steering column.
4 way emergency flashers were an option. Some trucks have the switch where cs65 said...under the instrument cluster bezel.
Another version mounted inside the glove box on a bracket.
What you are describing, IMO...is an aftermarket emergency flasher.
AFAIK, there is no factory switch like this mounted under the dash.
Why would there be two of these switches?
If the factory switch was defective, and a previous owner couldn't find a replacment switch, he/she went to a parts store and bought this aftermarket unit...bolted it under the dash.
Old Jul 31, 2009 | 01:38 PM
camperspecial65
Post a pic of it if nothing else....
a pics worth a million words they say...
- cs65
Old Jul 31, 2009 | 09:41 PM
Wyatt66f100
it looks ford
Old Jul 31, 2009 | 09:42 PM
Wyatt66f100
see? i had sanded it earlyer the black paint was chipping off anyway. ill prolly repaint it.
Old Jul 31, 2009 | 10:33 PM
camperspecial65
looks like the 4 way flasher bracket seen in the glovebox of 1967 trucks...
- cs65
Old Jul 31, 2009 | 10:52 PM
Wyatt66f100
i thought 67s had them in the dash
Old Jul 31, 2009 | 11:40 PM
camperspecial65
Ive seen many in the glovebox...my ex brother in law had a 68 with it in the glovebox...
- cs65
Old Aug 1, 2009 | 10:15 AM
NumberDummy
C6AZ15595A .. Emergency Warning Flasher Switch Mounting Bracket / Mounts inside GLOVE BOX / Obsolete
Fits: 1967/69 F100/350 / 1966: Galaxie/LTD/Fairlane/Mustang/Falcon // 1970 Bronco.
Illustrated here: 1964/72 Ford Truck Parts Catalog / Illustration Section 145.2 / Page 12.
1970/72 F100/350: The emergency flasher switch is mounted on the dash.
MrHomz
33
May 21, 2019 11:20 PM
resonateur
Oct 6, 2014 10:05 PM
abe
Oct 3, 2012 08:31 PM
skyhawc
Nov 1, 2010 08:37 PM
Cracker289
Jul 11, 2010 03:24 PM
