Dash wiring questions.
Old Oct 5, 2014 | 07:59 PM
resonateur's Avatar
resonateur
As I'm getting into the dissection of my '66 F-250, I'm running into a few more mysteries that maybe someone can shed some light on. One is the momentary switch on the dash, just like a door jam switch. It appears to be period correct with no noticeable alteration to the wiring. Any guess as to its purpose? Also, another "turn/pull" switch just to the right of the steering column, next to the choke. A large flasher unit shares the wiring (appearing original) which is soldered to this switch, but there is also the original flasher unit mounted behind the instrument cluster. The bezel (original also) which trims this switch on the dash is blank. Is this for a trailer harness or camper?? Any other ideas? Thanks...see photos.
Old Oct 5, 2014 | 09:34 PM
Rbeck204's Avatar
Rbeck204
Dash wiring
The push button is for the windshield washer and the push/pull button is for an emergency flasher.
Rich
Old Oct 5, 2014 | 09:56 PM
resonateur's Avatar
resonateur
Rich:
Thanks a lot for your information. It will help me check the integrity of the original loom.
Old Oct 5, 2014 | 10:11 PM
Rbeck204's Avatar
Rbeck204
Dash wiring
You are welcome. I am right now in the middle of reinstalling the custom cab wiring harness in my 65 crew cab. I have been doing a lot of research and looking at wiring diagrams. Ask if you need more info.
Rich
Old Oct 6, 2014 | 05:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by resonateur
One is the push button windshield washer switch on the dash.
Also "turn/pull" 4 way emergency flasher switch just to the right of the steering column, next to the choke.
2C-11500 .. Windshield Washer Switch (Motorcraft SW-287) / Obsolete
1965 F100/250 with single or 2 speed wipers / 1966 F100/250 with single speed wipers / 1966 F100/250 with two speed wipers before serial number 760,001.
Originally this switch was used as the starter button on 1952 trucks!
With 4 way emergency flashers, there are TWO flashers behind the dash, one for the turn signals, t'other for the 4 ways.
Both flashers have two prongs and look identical, but the 4 way flasher is a H/D unit, as it has a louder CLICK.
Old Oct 6, 2014 | 10:00 AM
resonateur's Avatar
resonateur
ND:
Thanks for the details. It's amazing, referring to the technology of the era that, during an emergency, you would have to be together enough to operate the 4-way flasher switch. If anyone is looking you can still find those pushbutton switches for both Ford and Chevrolet cars of the 50's. Some have spade terminals and some have sockets like the one depicted.
Old Oct 6, 2014 | 12:43 PM
NumberDummy
How many would'ja like? 2C-11500 ~ Green Sales has 2 & Carpenter has 1,426!
Look at the bright side, at least the 4 way switch is EZ to access.
1967/69 F100/350's have the 4 way switch mounted to a bracket on the inside of the glove box!
Old Oct 6, 2014 | 09:24 PM
resonateur's Avatar
resonateur
So, I have seen an emergency flasher "jewel" indicator lamp in the parts catalogs. Is that something my '66 may have had, or is for other years? I'll have a blank space where the dash controls reside, as I'll be abandoning the dash-mounted choke control. The indicator lamp would look cool next to the flasher switch.
Old Oct 6, 2014 | 09:34 PM
Rbeck204's Avatar
Rbeck204
Dash jewel
I put the dash jewel in place of the choke cable, just like you are thinking. Be aware you will have to enlarge the hole. FYI
I think it looks good there.
Rich
Old Oct 6, 2014 | 09:48 PM
resonateur's Avatar
resonateur
Rich:
Thanks for the advice. I do think it makes sense to indicate the purpose of the E-flasher. Did you solder the wiring to the 4-way switch or splice into the wiring?
Thanks again for your input!
Old Oct 6, 2014 | 09:52 PM
resonateur's Avatar
resonateur
Looking at the diagram more closely, I see two leads with sockets on the flasher leg. I'm going to guess these would be for an indicator lamp!
Old Oct 6, 2014 | 10:02 PM
Rbeck204's Avatar
Rbeck204
Flasher wiring.
My wiring all plugged in, including the light.
Rich
Old Oct 6, 2014 | 10:05 PM
resonateur's Avatar
resonateur
Mighty fine!
zstangkrewson
Jul 3, 2013 07:22 PM
yetiman
Mar 24, 2009 05:09 PM
Franciss
Jun 1, 2004 10:48 AM
oldschool63
Dec 22, 2003 07:23 PM
Binford
Apr 6, 2002 09:56 PM
