Sponsored by: Real Truck
changing fuel filters
Old Jul 30, 2009 | 11:47 AM
bob 2008 F250's Avatar
bob 2008 F250
i'm changing the fuel filters on my 2008 f250 6.4 deisel. I located the primary filter and opened the drain to release the fuel in the filter housing as per instructions. 15 mins later its still draining. how long doers it take to drain? am I doing this right? I called the local dealer and could not get an answere. thanks
Old Jul 30, 2009 | 11:56 AM
CampD's Avatar
CampD
Yikes!! thats a little long, should only take a couple mins to drain, you are using the water drain to release it?
12ozd's Avatar
12ozd
It may drain for a while,no need to wait for it to stop.
Change the filter,and keep going !
You're really just removing any water by draining.
(as well as draining the housing).
Some people will jack up the truck to help w/ that.
Old Jul 30, 2009 | 12:08 PM
bob 2008 F250
yes I'm using the water drian. is that right?
Old Jul 30, 2009 | 12:15 PM
GregsSD's Avatar
GregsSD
Yes, you are correct in using the water drain plug to drain it.
It's better to change your filters when you don't have very much fuel in the tank. I think it is just siphoning fuel out of the tank.
I usually only get about a quart at the most of fuel to drain out when I change my filters. But I make sure to do it when I am below 1/4 tank.
Old Jul 30, 2009 | 12:25 PM
bob 2008 F250
thanks, i got in touch with a service tech at a local ford and he tells me that the fuel will never stop because it creates a syphon effect as you metioned. seems a little messy but i'm gonna give it a shot
aphotic26
6.4L Power Stroke Diesel
Nov 25, 2013 09:43 AM
kje
Jun 16, 2013 06:39 AM
vancouver f250
Apr 23, 2013 04:40 PM
justin1795
Jan 30, 2012 03:34 PM
timmosazz
Aug 14, 2003 03:35 AM
