Sponsored by: Auxito
exhaust leak
Old Jul 29, 2009 | 04:35 PM
ryan_fordguy's Avatar
ryan_fordguy
Question exhaust leak
HI everyone, i need some help... My 2001 f-150 has an exhaust leak from the manifold on the passenger side. When i looked for it i noticed that one of the bolts holding the manifold on broke off!! The bolt is sticking out almost enough to grab it but not sure if i can and if it will even budge! Anybody got an idea?? i dont want to take somewhere and get charged a ton for it! Any easy way to take the manifold off and do it myself??
Old Jul 29, 2009 | 07:23 PM
LxMan1's Avatar
LxMan1
Real common for the studs to brake. I would remove the manifold and replace all of them with new stainless studs from your local Ford dealer. Replace the gaskets as well.
Old Jul 29, 2009 | 10:36 PM
ryan_fordguy
Thanks, any real easy way to get it off? Its my Passenger side manifold.
Old Jul 30, 2009 | 02:26 PM
ryan_fordguy
If i take the manifold off will the bolt come right out? I have heard i might have to drill it out?! I dont wanna do that...dont trust myself
Old Jul 30, 2009 | 05:43 PM
bnovak's Avatar
bnovak
Spray all of the studs that you are replacing with aerokroil or PB blaster the night before you start the project, and then about an hour before you dive in. And no, WD40 doesn't count The oil will penetrate the threads and help loosen the studs up. It also helps to have a MAPP gas torch - if the studs are really in good and the penetrating oil isn't working, heat the area around the base (block) of the stud and then start backing it out. A good pair of vice-grips will make this project a lot easier.
Old Jul 31, 2009 | 10:05 AM
papajoemrt's Avatar
papajoemrt
In addition to spraying the studs with aerokroil or pb blaster, drive around after spraying it to heat it up. then let sit spray again the night before, then spray before the mayhem begins. make sure to use stainless, and if you have any future plans of headers of any kind then save the work later and do them now.
Old Jul 31, 2009 | 02:05 PM
dblake37's Avatar
dblake37
You may want to take the manifold somewhere to have it machined before you put it back on.
Old Jul 31, 2009 | 02:33 PM
ryan_fordguy
Thanks alot everyone for your input! I heard that if i spray the crap out them the night before it shouldent be to bad, other than it takes time! To get stainless studs do i need to go to the dealer or can an autozone or oreilys or napa have them?
Old Aug 1, 2009 | 12:49 PM
papajoemrt's Avatar
papajoemrt
The dealer sells the stainless steel manifold studs. I looked into them when I was trying to diagnose a ticking sound and i think they were around 7 or 8 dollars a stud, I remember them being expensive. I'd go with these and not autozone, oreilys, or napa even if they have them. You get what you pay for.
RedBandit
19
Oct 23, 2020 02:01 AM
tommylg
13
Feb 16, 2017 09:23 PM
jawdoc
Nov 18, 2014 06:45 PM
danohall
Oct 20, 2007 03:35 PM
93zulu
Feb 26, 2006 07:13 PM
