Rebuild / Replace hitch platform?
Old Jul 28, 2009 | 09:00 PM
Forest's Avatar
Forest
My 2003 Excursion hitch platform is still performing its function, but...the hitch pin hole is badly egg shaped from repeated hammering. It is getting worse.
I tow a heavy travel trailer. The drawbar will slip in the receiver box, even with plenty of weight distribution spring bar torque. I now have about 1/8" of axial slip when braking. The hitch is also starting to rust.
I know you are not supposed to cut or weld on these hitch platforms, but I cannot imagine how it could be harmed. I seriously doubt that this is HSLA (high strength low alloy) steel. It should be acceptable for a talented weld shop to repair the elongated hole. To be sure, however, I may just buy a new platform and install it. Monsta has provided good instructions on how to drill out the shear head bolts and I think I could install it.
Opinions? Any other options?
Old Jul 28, 2009 | 10:55 PM
gr8scott72's Avatar
gr8scott72
Are you talking about the pin that holds the ball shank in?
Why not just weld a plate with a hole on each side and use a longer pin?
Old Jul 29, 2009 | 07:56 AM
Forest's Avatar
Forest
Scott,
I am thinking the same thing (repair by welding). Two (2) problems with this:
1) Label on platform clearly states not to "cut, drill or weld".
2) Locking pins will no longer fit due to the distance from one side of receiver tube to the other.
I'm thinking of removing the platform so that the pin hole can be "filled" with weld metal and then re-drilled.
Old Jul 29, 2009 | 08:53 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I'd just get myself a newer, better hitch and be done with it. The last thing you want is to be like Fred Flintstone and watch your own trailer pass you....or worse yet, wonder where you trailer went....
Old Jul 29, 2009 | 08:55 AM
gr8scott72's Avatar
gr8scott72
Scott,
I'm also wondering how your pin hole got so wallowed out. Is your pin too small?
Old Jul 30, 2009 | 10:00 AM
Deno346's Avatar
Deno346
I had the same problem, the typical receiver pins have a dog leg on the end to make it easier to graband not pull through. That dog leg is what caused the pinhole to wallow out. I replaced it with a straight pin that has a head on it to keep from pulling through.. Condition has not worsened.
Give that a shot until you get it repaired or replaced.
Old Aug 11, 2009 | 06:45 PM
Forest's Avatar
Forest
I'm going to buy a new hitch platform and do the work to replace it. The only confusion regards the correct part number. One dealer quotes YC3Z*17D826*AB for $499. Oddly, the other dealer quotes YC3Z*17D826*BA for $182.
I can get the 2 correct shear-head bolts (1C7Z*17758*AA) as well as other 6 bolts (*W708772*S439).
Can anyone report the correct part number for latest class IV (1250 lb / 12K ) hitch?
Old Aug 12, 2009 | 02:43 PM
Forest's Avatar
Forest
I think I just figured out my own question. The $182 part number was the reinforcement bracket inside the rear bumper. YC3Z*17D826*AB is CORRECT--it is the Class IV hitch receiver platform.
Old Aug 12, 2009 | 02:52 PM
YellowSled's Avatar
YellowSled
Not much diffrent from OCD, it appears you have OCT(towing)!
Old Aug 12, 2009 | 03:01 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
Regardless of how you fix it...the cause I believe is how Deno describes it...
Either use a straight PROPERLY RATED hitch pin for your load...or you can do as I did...a $0.10 hose clamp at the crook of your pin and the crook doesn't ride into the hole and wallow it out...mine wallowed until I did this and now it is wallowed BUT stable...
Please note that the photos below are not of my setup but a close friend of mine...
Good luck!
Joe.
Old Aug 12, 2009 | 07:52 PM
UrbanXX's Avatar
UrbanXX
There is a repair for the problem you are having, if you go to a D.O.T. approved shop they should be able to put a sleeve in each side the hitch. Just make sure thay are D.O.T approved.
Stuff like this is done on big trucks all the time. Check out a truck repair shop that cuts frames and does drive shafts, just see what they say.
Old Aug 12, 2009 | 10:26 PM
Forest's Avatar
Forest
Hey, at least I'm not OCL (Lift)!
F250_
37
Aug 11, 2020 10:35 AM
quincyj34
20
Feb 11, 2015 08:00 PM
signut
Oct 15, 2014 05:26 AM
mmcd7006
Nov 18, 2012 06:59 PM
luisp1966
May 10, 2012 10:45 PM
