Harmonic Balancer
Old Jul 28, 2009 | 11:32 AM
RUredE's Avatar
RUredE
Harmonic Balancer
I bought a 1971 429 short block and installed a cloyes double roller with a 3 keyway crank gear. I installed the crank gear straight up and go to put my balancer on and its reading 30 degrees after. Does anyone know what the Ford part number of the balancer should be. I'm thinking I have the wrong balancer.
Old Jul 30, 2009 | 12:13 AM
Dirt racer's Avatar
Dirt racer
Not sure what the ford part number is, but I have been running a Powerforce damper on my 70 429 since 2004 with no problems. CNC-Motorsports.com sells them for $67.25.
BB Ford 429-460 Powerforce 6.7" street damper. part number PP-80008. My original one was pretty cracked up. I would recommend a new one if yours looks like mine did.
Old Jul 30, 2009 | 08:14 AM
mark a.'s Avatar
mark a.
I don't think a 385 series balancer will fit on anything other than a B.B.
Old Jul 30, 2009 | 08:42 AM
RUredE's Avatar
RUredE
Thanks,
I went with ordering the Powerforce dampener.
I was thinking the same that a 385 series balancer only fits the B.B. but its not lining up properly on the crank nose keyway, If I installed it on the timing gear keyway which is 45degrees off the nose keyway then it would work.
Old Jul 30, 2009 | 10:28 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
That rubber is 38 years old.
No wonder it has spun.
genn
1983 - 2012 Ranger & B-Series
Oct 29, 2014 08:37 PM
JRS2
Apr 15, 2014 08:57 PM
TPyle
Apr 12, 2014 04:45 PM
Becky_is_a_66
20
Jan 28, 2014 10:04 AM
Rich Halsey
Aug 12, 2013 11:50 AM
