428 Flywheel
Old Apr 8, 2014 | 05:40 PM
TPyle's Avatar
TPyle
428 Flywheel
What suggestions do you guys have on an aftermarket flywheel for a 428? Also my engine doesn't have a harmonic balancer just the crank pulleys. I assume even though it is externally balanced it should still run a harmonic balancer?
Old Apr 12, 2014 | 04:45 PM
yellow truck's Avatar
yellow truck
I have a McLeod in mine. Yes, you should have a harmonic balancer. They do different things. One replaces the need to balance the crank, the other addresses the vibrations set up by the engine firing and pushing on the crank.
bigdan1979f-250
Dec 7, 2011 06:44 PM
gquinn8516
May 7, 2009 04:17 PM
raceman712
Apr 14, 2006 10:25 PM
Power_age
Dec 14, 2004 02:31 PM
marty68
Oct 31, 2004 06:31 AM
